M8 Vibration
Old 06-10-2018, 08:15 AM
flyboyron's Avatar
flyboyron
flyboyron is offline
Default M8 Vibration
I took 2 bikes for a demo ride yesterday. I rode the Fat Bob 114 and the Heritage Classic.
I noticed both bikes at above 70mph, there is a vibration, that after a couple of miles will make my hands start to go numb.
I don't know if the Heritage had the 114 or the 107.
Is that common on the new M8 bikes?
Old 06-10-2018, 08:27 AM
GPHDXLC's Avatar
GPHDXLC
GPHDXLC is offline
All I can tell you is my son has a 16 Slim and it's like you said at higher speeds. But my hands never get numb, it's just not as smooth running as my King at high speeds. In town and at stops his is smoother. I test drove a new 114 heritage and it felt about the same as my sons 16. On the freeway I like the rubber mount better. Any other time, not a big deal to me.
Old 06-10-2018, 10:05 AM
SomeOld Biker's Avatar
SomeOld Biker
SomeOld Biker is offline
My M8 RK is so smooth at speed I have to be careful I don't take a nap!
The following 2 users liked this post by SomeOld Biker:
02603SEC (06-10-2018), mjwebb (06-10-2018)
Old 06-10-2018, 10:24 AM
KrustyKush's Avatar
KrustyKush
KrustyKush is offline
My 2018 RGU is smooth. At idle, there is a bit of a thrum, and it has a slightly off-kilter nature, but very little actual shaking. Once rpm rises above idle, most vibration goes away and does not return at any higher rpm. My M8 is much smoother at idle than my 2016 Ultra Classic (air cooled) was, but pretty much the same as the 2016 at all speeds above idle.
Old 06-10-2018, 12:25 PM
VDeuce's Avatar
VDeuce
VDeuce is offline
Softail is rigid mounted with dual counter balancers. They tend to buzz at 3k and up, most noticeable on long rides after stopping. My twin cam Deuce did it pretty bad. Touring bikes are rubber mounted so smoother.
Old 06-10-2018, 12:30 PM
FatBob2018's Avatar
FatBob2018
FatBob2018 is offline
Received 2,474 Likes on 1,353 Posts
My Fat Bob had notable vibration in the handlebars when new, and probably would have led to numb hands. I replaced the handgrips with Kuryakyn ISO grips with bar end weights, and it's now glass smooth.
Old 06-10-2018, 01:34 PM
JohnTz's Avatar
JohnTz
JohnTz is offline
Mine is smooth as glass past idle and below 4K RPM. At 4K it’s start to vibrate a little until 4250 then smooths out. I rarely go past 4K anyway so I never notice it. This is for a RGS.
Old 06-10-2018, 03:03 PM
nykn72's Avatar
nykn72
nykn72 is offline
18 CVO RG .....no numbness here
Old 06-10-2018, 03:05 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,988 Likes on 17,898 Posts
Must be you I've ridden rice bikes with more vibration than my M8, thing so smooth you forget it's a harley.
Old 06-10-2018, 03:22 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 30,863 Likes on 11,600 Posts
And I have to remember to check the speedometer.
Quick Reply: M8 Vibration
