Check engine on display but no oil light
Rolling into get fuel today I had the i button pushed so the ambient temp, oil pressure and EITMS status were displayed. Just before I shut down the engine,to get fuel, the "check oil" appeared and the oil light did not activate. I started the bike right again and "OK" appeared. This happened several times during the day and I will admit that I don't usually have this screen up when stopping. I mostly check this screen on the fly and the oil pressure has always read "OK" and the oil light has never activated.
I would except that both the oil light and the "check oil" would activate at the same time. There is just one oil pressure switch and one sender according to the manual. Wiring diagram shows 3 wires, one power wire, a ground and a signal wire.
What's going on?
2017SGS- build date 2/17 -stock and no sumping issues. Oil level has been consistent in the 11,500 miles so far.
What's going on?
No, I rolled in to get some fuel and just before shutting down check oil came on ( no light). Seems to happen when the bike goes from operating oil pressure to idle pressure but if I leave the bike running after stopping it switches back to OK. Is the display signal/input (or whatever) sensitive to the sudden change in pressure?
If You are talking about a check oil indication on the display, rather than the oil light on. I have seen that many times,and it is arbitrary. However recently the oil light came on.It threw codes p0522 and p0523. These point to the oil pressure switch. Switch changed under warranty. So You might want to check if You have an ECM code. If not,I would ignore the indication.
