SE Tuner & PowerVision required for Stage 2??
Old 04-15-2018, 11:32 PM
lithod02's Avatar
lithod02
lithod02 is offline
Default SE Tuner & PowerVision required for Stage 2??
I was told by dealer where I bought my 18 SGS, that a SE Pro Street Tuner and Power Vision were required to keep warranty when doing a Stage 1 or above. Anyone else heard of this? Sounds like they just want to sell more parts.
Old 04-15-2018, 11:34 PM
lithod02's Avatar
lithod02
lithod02 is offline
Also I bought the extended warranty, if that would make a difference.
Old 04-15-2018, 11:58 PM
davewear's Avatar
davewear
davewear is offline
That’s kinda ridiculous never mind it doesn’t make sense... get them to put that in writing lol.
Old 04-16-2018, 12:04 AM
lithod02's Avatar
lithod02
lithod02 is offline
Yea kinda what I was thinking, they said they would tune it with the PV and put the tune on the SE Tuner and if it was hooked up to a computer MoCo would only see the SE Tuner to keep the warranty. So a PV voids warranty? Couldn't get a straight answer from service department.
Old 04-16-2018, 12:13 AM
1Canuck's Avatar
1Canuck
1Canuck is offline
Received 2,252 Likes on 1,439 Posts
A load of crap that is. The PV is superior to the street tuner. But they are both tuners. Tuning with PV will get a good tune Pretty much only the VE can be pasted into the street tuner and then flashed to the ecm. But some of the PV data already in the ecm will be overwritten. Really do not know if they are scamming you or they do not know what thye are doing.
BTW, the SE street tuner flash will protect your warranty.
Old 04-16-2018, 12:19 AM
lithod02's Avatar
lithod02
lithod02 is offline
Well if the PV overwrites anything in ECM, maybe that is what they mean by using the SE Tuner. I will be calling a couple other dealerships for a second opinion. I can install my own air cleaner, and head pipes. Already did slip-ons. Just wanted dealer to do Stage 2 (cams and dyno).
Old 04-16-2018, 12:25 AM
1Canuck's Avatar
1Canuck
1Canuck is offline
The ecm comes with a stock map. Either/any tuner will write over the stock map. using an SE street tuner is the only tuner they (HD) say keeps the warranty. The PV is capable of fine tuning the timing and more. The SE street is limited to a preprogrammed file for HD only add on parts.
Old 04-16-2018, 12:30 AM
lithod02's Avatar
lithod02
lithod02 is offline
Got it, thanks for the info. Going to do some calling around and see what I can come up with. May be able to get away with just SEPST at another dealer. Just wanting more sound and power from M8 like everyone else
Old 04-16-2018, 07:52 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 9,349 Likes on 4,769 Posts
if the Mothership finds they are using a non compliant tuner on an otherwise compliant tuned bike they are in deep doo doo $$ penalty wise..that's a huge no no
Attached Thumbnails SE Tuner & PowerVision required for Stage 2??-12673315.jpg
Old 04-16-2018, 10:20 AM
BVBOB's Avatar
BVBOB
BVBOB is offline
Here is what they are likely doing, they are probably loading a map from the "Street tuner" and then pulling it and modifying it with the PV, When read on the Digital technician it will read "street tuned" I have seen this at a local dealer and verified it myself
Quick Reply: SE Tuner & PowerVision required for Stage 2??
