Idle issue
Old 04-10-2018 | 08:07 PM
lhgdale's Avatar
lhgdale
Default Idle issue
Hello, I’m curios if anyone else has had this issue. I recently put cams, exhaust and intake on my 18 RGS. I used a power vision tune from Fuel Moto. The bike ran good but I would get some speratic idle issues. Getting off the throttle after some riding the idle would stay above 1200 rpm for about 10 seconds then fall back down to set idle. It would also surge up above 1000 rpm if cruising through a parking lot.
I had the bike dynoed yesterday hoping to get rid of that issue. The bike runs great but the idle issue is still there. I would appreciate any help and info. Thanks
Old 04-10-2018 | 08:10 PM
Quik's Avatar
Quik
Mine has done this since new, I just dont pay much attention to it anymore, 13k miles and hasn't caused any issue so I guess it's all good.
Old 04-10-2018 | 08:29 PM
lhgdale's Avatar
lhgdale
Thanks that’s good to hear but frustrating. I hate being at a red light and the idle be at 1200.
Old 04-10-2018 | 08:32 PM
mjwebb's Avatar
mjwebb
they all do that! mine stock thru dyno tuned SE Stage 1 periodically for no reason behaves like it has a mind of it's own..no big, working as designed I guess
Old 04-10-2018 | 08:41 PM
lhgdale's Avatar
lhgdale
I wonder if idling it lower helps out at all?
Old 04-10-2018 | 08:49 PM
VDeuce's Avatar
VDeuce
Check for intake seal leaks at the heads. There are a few reports of intake seals leaking and/or warped manifolds (plastic).
Old 04-10-2018 | 09:10 PM
badcooky's Avatar
badcooky
Usually that's a sign of being lean but it could be ECu malfunction ,mine doesn't do it.
Old 04-10-2018 | 11:47 PM
goose222's Avatar
goose222
I soon as I added 2-1 exhaust a cam and tune to match my idle has sucked when bike is cold. When I start it for the first time of the day it almost dies then catches itself then almost dies. Does that 3 or 4 times then smooths out. I’m assuming a tuning issue. Alls I know below 2800 rpm the bike is a pig. Can you tell I’m getting a little frustrated. With a little help and patience we will get it figured out. I’m glad the weather is shitty.
Old 04-11-2018 | 07:48 AM
TAKITO SEXY's Avatar
TAKITO SEXY
As VDeuce mentioned, checked for leaks, I also have a stage II and noticed the SE Heavy Breather was not sitting flush at the elbow when looking at it from underside, it had about an 1/8" gap. If I was standing looking at the bike from the right side, it looked correct, but it wasn't. Soapy water is your friend when trying to find air leaks.
Did about three auto tune sessions with the PV and runs a lot smoother also, no bogging in the lower RPM's.
Good luck!
Old 04-11-2018 | 08:18 AM
pittz5's Avatar
pittz5
was there a big big difference between dyno and Fuel Moto map? I’ve noticed the last couple maps I got from Jamie don’t have the idle setting available in map. Not sure why.
Quick Reply: Idle issue
