Touring Power Cam???
Curious if anyone has tried the HD Power Cam instead of the torque cam.....
And yes I have seen the MOCO dyno run comparision and understand different riding styles...........
Just like to hear from someone that actually put one of these in a BAGGER and if they can tell us about their results.......
Thanks
Eagle Out
Thanks
Eagle Out
I will be the first to admit I’m not an engine guy but have an amazing service manager near me. I told him I needed more power and I decided on the power cams because I’m mostly highway riding in traffic. He did what was essentially a stage 1 with screaming eagle heavy air flow power cams, TTS tuner. The turner allows you to save Harley settings, dyno, then reset with warranty issues.
The main power range is from 3000 rpms through 6000. At first it took awhile to get used to because I was used to babying it at 4000 but a good tech should set your rev limiter higher. After about 30 mph the change in torque is huge. Your acceleration snaps instead of gradually increasing. On a side not 6th gear now becomes overdrive only your max power is in 5th. Can’t remember dyno gains but I know factory stopped at 116 mph and I hit the needle at 120 pretty easy.
Not knowing engines very well I again deferred to the manager and he put me at a stage 3 +. The reason for the plus is he sent heads out to Vance and Hines to drill the heads? And now I’m at 116 torque and 108 hp. The difference he showed me is with Vance and Hines work max torque holds for almost 3000 rpm range and there’s is 1500. Here is latest dyno from stage 1 to now to give you idea.
On a dynojet dyno report it is possible to make the two scales different on one graph. This will cause the crossover points to appear to move. Without seeing both sides of the graph I cannot tell what is going on, so I will not guess at it. Since he said the heads were removed and sent out, I would assume this is a Stage III upgrade kit but it's hard to tell due to the statements being made. Someone is confused, misunderstood or has been lied too.
If anyone wants to challenge the authenticity of the dyno feel free. The bottom numbers are the stage 1 when I had power cams done with intake and Mastertune. The second set of higher numbers are a Stage III plus the head work by Vance and Hines. I trust the Service Manager completely who worked for Harley for 13 years and 5 for Vance and helping design cams. The reason he sends the heads out is because as you can see (or disbelieve) the goal is to maintain 100 lbs torque as long as possible. Mine lasts from 3000 rpm through 5250. If you look at a stage III by itself it’s approximately 1500 rpm range. I took the photo off the dyno screen so it is grainy but don’t need to alter a document just to offer my opinion on the cams alone.
Thanks
Eagle Out
Thanks
Eagle Out
Shortly after the 1000 mile service, I installed the SE Street Cannons, Ventilator, Power cam and Pro Street tuner.
Pulls strong off the bottom (I can drag it down to 2000 RPM and roll into the throttle deep, no downshifting, with no balking out of engine), and pulls hard from 3000 to the top (6150 or so).
Fun to ride now, I routinely run it to redline in 2nd and 3rd when out for a run, 5500 in 4th, then back to normalcy in 5th and 6th. Just rode another torque cam equipped M8 Sunday. I don’t believe my riding style fits with the power band of that particular camshaft.
Maybe when I am older, but who knows, I will be 55 on the next one, and I still love to ride at the upper portion of the tach. swing. BTW, 4687 miles on the clock when I parked it Sunday.
