Spark plug boot tool
Old 01-19-2019, 08:16 AM
lp's Avatar
lp
lp is online now
Received 2,853 Likes on 1,601 Posts
Although not always recommended, in a jam you can just twist the boot a little and pull out the wire like you've probably done on every car or bike you've owned.
They come right out without the need for any tool. Done it many times without any issues.
  #32
sixguns's Avatar
sixguns
sixguns is offline
Received 1,481 Likes on 761 Posts
[QUOTE=Ridetothehill;17971040]The lisle 51750 may not fit in that tight space. I just ordered the 51250. Did anybody bleed the pressure from the fuel system before removing tank. The book says to unplug the connector for the fuel pump, then run the engine until it dies. Crank the starter to make sure there is no fuel pressure.
[/QUOTE
The tool 51750 works, its the angle that makes it a winner. Never tried the 51250 it may be a winner too... Good Times...
The following 2 users liked this post by sixguns:
GTK (01-20-2019), Ridetothehill (01-19-2019)
  #33
Old 01-19-2019, 08:33 AM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,854 Likes on 1,001 Posts
I own the Lisle 51250 and have used it on the inside plug boots. It seems to work well. I also have the pliers with the rounded hook end. The 51250 worked so I don’t know that I even tried the pliers. As far as disconnecting the fuel line, if you don’t relieve the pressure a little gas will come out. It has always just dribbled out, but for safety’s sake don’t put your face close to the connection while you’re disconnecting the line.
  #34
Old 01-19-2019, 10:01 AM
Ridetothehill's Avatar
Ridetothehill
Ridetothehill is offline
Thank you $tone. I was wondering about that fuel pressure thing. I don;t want to start the bike up on the jack. I'll just wrap a rag around the tank quick disconnect.
  #35
Old 10-25-2019, 08:02 PM
tonyd2017's Avatar
tonyd2017
tonyd2017 is offline
my front under tank plug wire rubbed and now it is no good. check them damm wires. The spark plug gap opened up quite a bit, .041 and bigger with 31,000 miles on plugs.
  #36
Old 10-25-2019, 08:30 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is offline
Received 18,197 Likes on 7,371 Posts
I've pulled my tank 4 times in two years and have never done that.
  #37
Old 10-26-2019, 06:38 AM
skratch's Avatar
skratch
skratch is offline
Received 4,370 Likes on 2,543 Posts
Originally Posted by fourburgs
Gonna try Lisle Tool 51750 Adjustable Engine Spark Plug Wire Puller . I had a hard time pulling those off as well . Can they make it any harder to change plugs ?
at least you don't have to take the wheels off to do it..... unlike my truck.
I've never lost more than a drop of fuel when removing the tank. usually less of an issue if you are working on a cold engine, and haven't turned on the ignition in a while
Ridetothehill (10-26-2019)
harley roadking
10-16-2021 07:00 PM
Curt3
Milwaukee Eight (M8)
17
07-22-2021 09:17 PM
sk8climax
Shovelhead
17
05-19-2016 06:40 AM
grippper293
07-01-2007 11:13 AM
drumer66
04-15-2007 04:51 PM
Quick Reply: Spark plug boot tool
