question on stock bike or stage one (engine)
Didn't quite know how to title the thread, but curious on all your thoughts. In the past with the 103 motor, I always did stage 1 right away or more, especially since in CA this bike ran so hot. I got a new bike that is strictly used as a commuter, I don't want to put a bunch of cash in it, as I am going to run the miles up fast. I am fine with the M8, its output but curious if doing a stage one, helping it breath better would help the motor last longer. Or is the motor running fine stock, that I can run 100k miles on it no problems. Mainly just curious on longevity of the motor, don't care about this bike having power etc. Thanks
The great thing about the M8 engines is that stock is just as good if not better than a 103 stage 1, so why spend the money. I'm done with that. Slip ons and that's it for me, plenty of power in the m8
pcwizard (08-22-2018)
I got a new bike that is strictly used as a commuter, I don't want to put a bunch of cash in it, as I am going to run the miles up fast. I am fine with the M8, its output. Or is the motor running fine stock, that I can run 100k miles on it no problems. Mainly just curious on longevity of the motor, don't care about this bike having power etc. Thanks
It runs fine stock. Where did you get the notion that a stage 1 extends engine life? Plenty of stock bikes that are durable. In fact you could argue that modifying the bike makes it less reliable.
I always assumed with the old twin cams I owned, that they ran so hot and so lean that it was not healthy on the motor. I always did a stage one and pipes to help it run better, not so lean. The M8 runs pretty damn good, I wondered if I needed to do a full stage one, air cleaner tuner slips at least etc to increase longevity. I could be very very wrong on that though. I thought about a tuner, slip ons and air cleaner, but thinking about it now, I guess its still chocked up with the head pipe and cat, so its not truly breathing and still running in a choked up state. If stock is not super lean, I might just keep this commuter stock. As the last commenter wrote, better to use the money for service items
Do you run out and buy a stage 1 for every car you buy?
Relax.
congrats on the new M8, they're great! mission accomplished staying put for your goals..i do believe opening the floodgates so to speak on increasing air throughput over the OEM restrictions is beneficial but not necessary for durability, reliability, longevity & fuel economy..the money you save will buy maintenance, gasoline, tires, etc
