Rocker Box Gasket Leak??
Old 11-07-2017, 09:05 AM
pomeara's Avatar
pomeara
pomeara is offline
Default Rocker Box Gasket Leak??
Dealer caught a rocker box gasket leak at 1K maintenance service. At 3,300 miles on 2017 CVO SG no other issues.
Has anyone had more than one gasket leak? Just curious if this will be a recurring issue
Thanks
Old 11-07-2017, 09:21 AM
plasmadaddy's Avatar
plasmadaddy
plasmadaddy is offline
Mine too disappointingly....
Being replaced next week so hoping it'll solve the problem once and for all.
Pretty poor for a brand new bike!
Old 11-07-2017, 12:37 PM
Psycho Dave's Avatar
Psycho Dave
Psycho Dave is offline
My dad's is leaking on his 17 under 500 miles.
Old 11-07-2017, 02:19 PM
Carlos3621's Avatar
Carlos3621
Carlos3621 is offline
mine leaked also, they blamed it on powder coating.
but another dealer fixed it under warranty. They said it was common and I think their might be a new updated part number for the upper cover gasket.
Kimbob (10-07-2020)
Old 11-07-2017, 06:41 PM
tenn volunteer's Avatar
tenn volunteer
tenn volunteer is offline
Veteran: Marine Corp
300 miles on my new Limited and I noticed an oil leak. Front rocker box gasket was changed; with the updated gasket. 4 days after the repair, the same oil leak again. HD elected to replace the front rocker box. I've ridden 3200 miles since and the engine is still dry. So far, so good ?? !!
eubanks (07-16-2018)
Old 11-07-2017, 07:36 PM
Woffski's Avatar
Woffski
Woffski is offline
Mine leaked also. Took it to the dealer and was told that they could not find a leak. Took it in for 1K check and didn't clean the bike, so there was evidence of the leak at the front and rear of the rocker boxes. They tighten everything up and we will see...
Old 11-07-2017, 08:41 PM
thereal142's Avatar
thereal142
thereal142 is offline
My front rocker box was leaking at 5000 miles. Dealer replaced gaskets; now leaking again at 7300 miles.
Old 02-14-2018, 03:09 PM
Bruce 140.6's Avatar
Bruce 140.6
Bruce 140.6 is offline
This happened at my 15K and 20K service and dealer said the same thing both times...
Rocker Box is leaking pretty good but we can fix it at now charge under warranty.
I have a 2016 883 and seems like this is common issues with 16 and 17 models?
Any one have any insight on what might cause the leak or other things to look at for?
Old 02-14-2018, 03:54 PM
ntg433's Avatar
ntg433
ntg433 is offline
I had a 2008 1200C and had to change the gaskets a couple of times. My suspicion is that during the chroming process the rocker boxes become warped. Additionally, sloppy cleaning of the part after milling allows an uneven buildup in the gasket channels which totally screws up the evenness of the chrome layers and the gaskets do not seat properly.
After the first time, I used an airplane high temp sealant very liberally, and the problem never returned. Sad, this should not be happening.
Old 02-14-2018, 06:46 PM
Heritage07's Avatar
Heritage07
Heritage07 is offline
Synthetic oil being more thin perhaps?
Quick Reply: Rocker Box Gasket Leak??
