Does adding slip on exhaust require tuning or hi-flow A/C?
Won't fit sn M8. The M8s have different diameter pipes.
Most people recommend a tune with open flow slip ons. I think the rationale is that in the stock configuration, the exhaust restricts flow more than the AC. Open the exhaust, you get more flow, and need more fuel. Then when you add a more open AC you again get more through flow, and need to tune.
I am about to do mine. Because, since I swapped my '17 Road King for SE Street Cannons, i get a bit of pinging when I really get on it, and the torque seems to drop off about 3,800 RPMs. Both signs of running too lean. But, I could live with it. I'll be curious, and will post the results after I do the tune.
