Battery tender plug in.
Bought a battery tender for my 17 rk special went to install the plug on the bike and pull the cover and find this plug on left side of bike. Is one already on the bike? I don't see where it comes back to battery and it is not installed on the top battery posts. Does it come installed on the bike? The plug matches the tender but concerned that isn't it.
09IronRider (10-22-2017)
bmedeiros678 (11-11-2021)
There are a couple of suggestions where the "Factory installed Tender" wire ends are located/connected .... Without messing around through all the wiring etc ,, does someone know where they are connected for future reference ???
If your bike does not come installed with battery tender cable ,,, the cable you buy,, the ends ,, would go to battery terminals ....
Thanks everyone and yes GTK it was in the manual and was unclear because it also talked about installing one as well. Since the tender came with terminal connectors and the one on the bike wasn't attached the the positive and negative terminals nor could I locate an inline fuse like on the one that came with it I thought I would ask the great group of people on the forum knowing someone would have to be a dick about it.
The following 2 users liked this post by 09IronRider:
edyvans (02-26-2022),
Noodles107 (03-15-2024)
