Milwaukee 2018 Street Bob Clutch cable adjustment
Does any one knows how to ajuste the clutch cable on a Street Bob 2018 ... My clutch cable as about 1 inch of free play. The cable is not the same at all as my 2016 Iron 883. It as a reg plastic cover and have no clue on how to ajust it. Thats for the help
no worries, figured it out
just in case if anyone else is wondering.. following is how you do it. apologies for the wrong terminologies in advance.
1. undo the leaver from the handle bar.
2. pull cable slightly and un-hook from the lever.
3. pull white plastic cylinder from the lever and free the top of clutch cable
4. lift up the cover for the self adjusting bit (you will see yellow internal with red button.)
5. gently push the red button out from the back of the botton.
6. lift up the little brass tab upwards from the inside of the yellow internal bit..
7. gently crack and separate top of yellow bit (its made out of 2 pieces)
8. you will be able to push the cable down and un-hook 2 cables away from each other.
Hope this makes sense and is helpful for someone out there
FTW-DIY (09-23-2019)
Beware !
The yellow housing is actually two pcs. The (taller) lower section is thin and flimsy where the two pcs. join.
Sure enough mine was cracked from the showroom but cable still working. Since I was changing handlebars I replaced the upper cable with a longer one.
The yellow connector is included with 2018 HD upper clutch cables.
The new modular upper clutch cable with compensating spring is clever but the plastic connector won't stand the test of time in my opinion.
