Trans, there is a fix !
#141
Apparently I am going to have every post I make parsed and argued by each of Steve's acolytes. OK, it's your turn.
You imply a close relationship with him, and say you're positive he doesn't want to pursue legal action. Why not? If he has been as patient as you say, and he is as wronged as he says, legal action seems to be the best recourse.
#142
On the bike in question I have never touched it for testing, it is and always has been 100% as supplied by HD other than a replacement HD Stage I air cleaner, AIM lockup clutch cover and HD 1200N clutch springs.
All of my testing of possible fixes has been on different bikes for this issue. I purchased the earlier clutch slave cylinder (14 - 16) but it does not work due to fitting changes on the clutch line. The pushrod appeared to me to look the same in the parts book so I did not buy that.
#143
So Steve, you got 2 bikes that do it.. I take it that the other one is the one with all the mods and testing you did?
#144
#145
Some on it and some on other customer bikes. It's not like I am the only one with these problems. I guess that might be a big difference when you only have one bike but I have customers who have near given up on HD over this and are hoping I will get back to working on this and come up with a fix for it. If I thought I had something that solved it, I could build 30 tomorrow and have them all out in bikes across the country testing in a week or so, as there is that many people wanting to try something, anything to fix it. So don't tell me MoCo doesn't know about it!
#146
I personally have run over 20 M8 Touring bikes and each and everyone has transferred transmission oil into the primary when tested. I own 2 and they both do it so I'm running 100% when testing for it. I have run 3 '18 M8 Touring's and they do it as well. I have also run a '18 Softail and the primary was overfull on it as well but I did not drain it first to make sure it was correct to start with. So I'm still on the fence if they do it or not. I have talked with shops all around the world, many of them are HD dealerships and they are seeing it too. So when someone says HD doesn't know about it or didn't know about it, I do not see how that is possible. I've know about it since Oct. 2017 and informed my dealership of it back then.
The biggest issue at shops is that most remove the drain plugs when doing a service and allow it to drain while doing the other parts of the service/inspection. So they never check the level prior to draining. At that point they would never know about it. If more start checking the levels before service work and noting it, the picture it would paint, I am afraid will look much worse.
They need to fix this fast, or in the near future the MoCo will be in big trouble. BTW I hope the 18 Softail you ran was just overfilled from the factory, I didn't think they would do it with a cable clutch. Keep us up-dated on the Softails please.
#147
The M8 is a big step for the MoCo. I feel they made many improvements. The problem is they are going to ruin it the way they are treating customers. They have some issues, they know it and so does everyone else. If they put half as much time as they do trying to cover it up, into fixing the issues we might have fixes by now. Instead they have chosen to deny issues and try to hang customers out to dry, then blame that on the dealerships. The new 2018 117 CVO bikes are already having sumpping issues! Go figure..... They blamed that last model year on SE parts as the cause, so what are they going to say now. The answer now seems to be, for the transfer issues, is that's normal.
I think there (Moco) in so deep right now they have no idea what's going on and denying is the only thing they know how to do. I have a customer that is on engine #5 for his 2017 CVO and it is at the dealership right now for sumpping again! Each time they send new engines and Stage IV parts. The dealership installs them and the last engine he asked the dealership to keep it and break the engine in so he could not be blamed for it. Got it back and it didn't go 1000 miles before it sumpped again. Sounds just the same as mine going back for fluid transfer issues!
#148
#149
The costs for the parts are about 40 bucks. So maybe you could try this fix?
#150
The '14 CVOs do have another pushrod which consists of 3 parts and it has a bigger diameter than the other ones. Some dealers in Germany tried this fix on their own. AT first it seems to work. The only Problem is, that those bikes haven't run many miles (in Germany we haven't such big distances like in the USA so most of our bikes don't ride that much) since the fix.
ocezam (11-01-2017)
