Transmission fluid transfer service bulletin
Old 06-24-2019, 08:44 AM
rossn2's Avatar
rossn2
rossn2 is offline
Had my 20K done Saturday (2017 RGU M8), rear tire replaced by local Harley Master Tech (owns own business now). Asked him to check primary prior to draining for fluid transfer, as I have been adding tranny fluid. Sure enough about 1 qt overfilled in primary. He called Dealer to tell them about the issue, and they pulled my VIN and said my Powertrain has been flagged by Harley, WTF? The only thing done to bike was August 2017 at purchase dealer put aftermarket pipes, air cleaner, and Stage 1 download using a DEALESHIP OWNED Powervision tuner.
So, Now I'm gonna have to fight with Harley regarding my warranty...A Word to everyone on this site. Harley is VOIDING power train warranties on bikes with basically anything from stock!
  #732
Old 06-24-2019, 08:49 AM
Heatwave's Avatar
Heatwave
Heatwave is offline
Member
Received 1,079 Likes on 639 Posts
Once you mated the Powervision (or any non-EPA approved Tuner) to the bike's ECU, the DealerTech computer immediately communicated with HD's Corporate Computer Network that the bike had a non-EPA approved tuner mated to it. At that moment your drivetrain warranty was toast. Unrecoverable. All factory and any HD ESP coverage for your bike's drivetrain was immediately flagged and voided. HD does NOT notify bike owners when they void their bike's factory or HD ESP warranty. The only way you'll ever find out if your drivetrain warranty is voided, is when you make a warranty claim or request a status of your warranty coverage directly from the dealer.
You can try to fight it but you have already lost.
  #733
Old 06-24-2019, 08:52 AM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 9,378 Likes on 4,784 Posts
dealerships are independent of the MOCO limited powertrain terms and conditions which clearly is stated in your Owners Manual is a contract between manufacturer and owner. The dealership should have known better and are not supposed to be installing what they did on a already compliant engine. Sorry but this is not HD being the bad guy..it's a misunderstanding and / or miscommunication issue between you and your dealership on what can and cannot be done in order to comply with the factory warranty rules
  #734
Old 06-24-2019, 09:05 AM
rossn2's Avatar
rossn2
rossn2 is offline
I just had the Clutch/Master Cylinder recall along with Rear rocker gasket replaced all under warranty within last 60 days...was never told my Powertrain was flagged. I think the damn tech must have hooked up the scan tool, which makes no sense...
  #735
Old 06-24-2019, 09:06 AM
rossn2's Avatar
rossn2
rossn2 is offline
The powervision tuning was done in August 2017 by the Dealership..
  #736
Old 06-24-2019, 09:09 AM
Heatwave's Avatar
Heatwave
Heatwave is offline
Member
Probably hooked up the DealerTech scan tool to see if there were any recalls for your bike. Once he connected...Flag popped up.... drivetrain warranty gone in an instant.
  #737
Old 06-24-2019, 09:57 AM
Maccam26's Avatar
Maccam26
Maccam26 is offline
Dealer called me this AM... Vent Kit is backordered.
  #738
Old 06-24-2019, 10:03 AM
Porkwrice's Avatar
Porkwrice
Porkwrice is offline
Originally Posted by stro1965
If you weren't being such a smart-*** I'd tell ya.
It’s ok man....I already know whatever you have to say is false anyway.....nobody wants to hear “don’t ride above 3000 rpm’s”, and “don’t pull the clutch in too many times” and “don’t go around right hand corners”. You can go back to having your feelings hurt meow.
  #739
Old 06-24-2019, 11:24 AM
mikes300's Avatar
mikes300
mikes300 is offline
bmmer, I got mine on friday from Surdyke and installed it saturday.
Maccam26 (06-24-2019)
  #740
Old 06-24-2019, 01:38 PM
Oldskewl's Avatar
Oldskewl
Oldskewl is offline
Received 7,922 Likes on 3,290 Posts
I hate to say it but you might as well wipe your *** with the HD warranty. The fine print clearly say's they can void your warranty if they suspect you abuse the bike by riding hard... That gives them the power to basically deny anything and everything they want.
I've never bought an extended warranty on anything expect my cars or trucks.
Quick Reply: Transmission fluid transfer service bulletin
