Transmission fluid transfer service bulletin
Old 12-07-2017, 09:30 PM
hattitude's Avatar
hattitude
hattitude is offline
Received 8,275 Likes on 4,443 Posts
So what wrong the a porous motor casting causing fluid transfer? Wouldn't it be the same as a leaky crank seal?
I know porous casting transfer is possible, and I believe HD had that problem on some shovelheads...
But porous casting transfer from trans to primary...???
Don't see how that's possible?
  #482
Old 12-07-2017, 09:37 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,991 Likes on 1,693 Posts
Originally Posted by lp
Logic is not welcome here. Stop it.
Originally Posted by harleytuner
My bad, for a minute there I thought I was on HTT lol
Leave whittlebeast out of this.
Same way gas migrates from the gas tank into the rear tire.
  #483
Old 12-07-2017, 09:39 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,019 Likes on 4,065 Posts
They guy said they replaced the motor so the motor was casing the vacuum in the primary just like a bad crank seal.. That caused the primary to suck on the clutch push rod hole.. Makes sense to me..
Add:
Technically it wasn't pulling directly though the motor-case.. Parts guys and salesmen don't have to be technical. I'm inclined to believe it was a misinterpretation of the facts somewhere..
  #484
Old 12-07-2017, 09:42 PM
IdahoHacker
A possible vacuum is one of the plausible reasons, but that doesn't include a porous case.
  #485
Old 12-07-2017, 09:44 PM
Max Headflow
Why not?
  #486
Old 12-07-2017, 09:46 PM
IdahoHacker
Why not?
While oil seepage through a porous spot is certainly not unknown, I would be surprised if the porosity were enough to allow enough air to move through the porous area to cause a change in pressure or vacuum.
  #487
Old 12-07-2017, 10:39 PM
Max Headflow
Well air is thinner than oil so it should make it's way through easier.. The crankcase runs at a slightly lower average pressure than ambient.
  #488
Old 12-07-2017, 10:55 PM
IdahoHacker
I understand what you're saying, but "seepage" happens a lot slower than "flow". I find it hard to grasp how air could work its way through a porous spot in an aluminum casing fast enough, and at enough pressure, to force oil to go where it's not supposed to go.
If that were happening, I'd expect that everyone who's experiencing oil migration from the transmission to the primary would have been talking about the loud farting noises when they opened the transmission to check the oil level.
If you know what I mean.
Now, pulling oil past an improperly sealing clutch pushrod, that's more plausible.
  #489
Old 12-07-2017, 11:17 PM
14Glide's Avatar
14Glide
14Glide is offline
Harley will have a transmission oil migration sensor on the 19's
  #490
Old 12-07-2017, 11:24 PM
IdahoHacker
Yeah, we laugh. Just wait.
Quick Reply: Transmission fluid transfer service bulletin
