zumo to infotainment transfer?
Received 14,670 Likes
Can't you just export the GPX file and import it into the boom? I would have to look at my zumo again and see what the file structure looks like but they should be compatible. Whether or not it's an easy thing to do might be another story.
I have never tried it because all my route info was all on my computer and ride planner.
I'd import the .gpx file into Ride Planner (or pretty much any nav software) then you can see the routes and check that they're 100% correct.
If not tweak as necessary and then resave onto a memery stick and import to your Boom.
Hey, you can't really be so lazy that you can't RTFM? Or use the search function? Already lots of responses on your other post on this subject. Most suggest you RTFM!
