has anyone drilled the M8 baffles? good or bad sound?
Old 05-12-2018, 07:43 AM
Crabchuck's Avatar
Crabchuck
Crabchuck is offline
I was looking at the tools I currently own and wondering what I can do to make it just a smidgen louder. I have some long carbide drill bits and was thinking about just punching four 3/8" holes in the end plate of the baffle. Any thoughts on why I shouldn't do this? Seems a less aggressive than cutting out the endcap like 04ctd's approach.
Old 05-12-2018, 09:05 AM
saafrican's Avatar
saafrican
saafrican is offline
I cut the the end pipe out of my exhaust pipe using a 42mm hole saw . You dont have to remove the pipes. It sounds a "little" Throatier and louder, but if you guys are looking for "loud" this isn't going to be enough. I removed mine because I wanted a less restrictive exhaust system ,with out paying $600 for slip on"s,
Old 05-12-2018, 06:17 PM
04ctd's Avatar
04ctd
04ctd is offline
doing small holes won't make a difference, doing my way barely made much difference. you should pay the ~$40 for the hole saw, so you can do your buddies bikes.
it's worth it
this is true, there are many posts about the M8 being too quiet.
it's physics: if you have a crossover or 2-1-2 it makes any thing quieter (cars, bikes) but if you run true duals, it makes it loud.
so it appears the 4 valve head is doing the same thing: making the exhaust pulses quieter.
IDK if this small mod helps, but the OEM setup is too quiet to keep cages from merging over on your bike, so I think this small mod is a good start,and it should be warranty friendly, so that makes it a no-brainer, esp if it helps the air flow thru the CAT and minimize heat from the CAT on your leg.
Old 05-12-2018, 06:29 PM
04ctd's Avatar
04ctd
04ctd is offline
video of the M8 Vance & Hines Power Duals with OEM slip on mufflers:
Old 09-06-2023, 02:33 AM
hmcidc/8404's Avatar
hmcidc/8404
hmcidc/8404 is offline
1st Gear
Default Yes, I drilled the M-8
But I must be honest with you and say that you want to do it cold because it leaves some nasty blisters...
Old 09-06-2023, 02:44 AM
hmcidc/8404
1st Gear
Finding after market anything is tough especially for the M8 107 but the Cobra slip-ons will work just fine till I get her in the shop for a whole new exhaust and intake. I am really surprised how nice the Cobra's sound. They sound like the big-boy Harley it is when hittin the gas or cruising at 65 on the highway yet won't wake the entire neighborhood at 6:30 am (unless I want to hehehehe)
DanTM
12-03-2015 11:45 AM
FLS103
10-17-2015 10:03 PM
Sallyman
04-05-2012 10:14 AM
Crushrus
08-22-2011 11:12 PM
gpp
02-14-2008 09:28 PM
Quick Reply: has anyone drilled the M8 baffles? good or bad sound?
