compression test on m8
08-04-2017, 08:22 PM
Had dealer do a compression test and a leak down test on a 2017 m8. Compression was 125 in each cyl and leak down 5%. Is this good?
08-04-2017, 08:43 PM
Cranking pressure should be well over 200 psi. Something is not right with those numbers.
08-04-2017, 09:02 PM
Why did you request a compression test? Actually surprised you could request that without cause.
08-04-2017, 09:03 PM
Quote:
Originally Posted by
stixvrad
08-04-2017, 09:30 PM
this sounds about as right as a chicken with lips. and everyone knows that makes zero sense.
The following 3 users liked this post by jclax01:
thereal142
perhaps they failed to disable the CRV
08-05-2017, 12:16 AM
On a stock 107 per manual.
ACR connected - 110 psi min
ACR disconnected - 175 psi min
Leak Down Test,,, 25% or better further diagnoses.
08-05-2017, 01:16 PM
psyshack
I'm pretty sure someone on this forum said they were running over 200. I think it was someone like Steve Cole, Jamie Long, or someone else that seemed legit. Also, I would jump the starter to do the test. No spark, fuel, or ACR.
I could be wrong.
08-05-2017, 03:53 PM
How did you hold the throttle blade open while doing the test?
Bob
08-05-2017, 04:10 PM
Take note djs asked here what the forum thinks of these results. Wonder why tech didn't offer their opnion? That is what's perplexing here
