2017 GPS not picking up local time zone
Folks, on the road and my manual is at home.
I'm I'm the central time zone right now, and the GPS didn't pick up the time zone change, it still displays the time in EST.
Is there a setting I'm missing that makes it display the time in the current time zone?
I took this from the pdf
https://www.harley-davidson.com/cont...Boom_OM_EN.pdf
The following text starts at page 49.
CLOCK
1. See Figure 31. Select Home > Setup > Clock.
2. 12/24 hour: Select 12-Hour or 24-Hour clock mode.
3. Press the multiselect button to choose GPS, RDS or User Time. a. GPS: Automatically synchronizes the clock with data from incoming GPS signals. GPS time is only available on radios with navigation.
b. RDS: Automatically synchronizes time with radio stations broadcasting RDS data. RDS is only available on radios manufactured for select regions that support RDS operation.
c. User Time: Time is manually entered.
4. Time zone: Select the time zone. For GPS time, AUTO causes the clock to adjust to the time zone for the vehicle
location.The clock updates as the motorcycle passes into other time zones.
5. Daylight savings time (DST): GPS time does not automatically account for daylight savings time. For GPS or user time, select DST On to advance the clock one hour (during spring in the northern hemisphere). Select DST Off to return to the original time.
6. Manually adjusting time: a. Manually adjusting time (User Time selected): Manually adjust the clock to the current time with the + and - controls.
b. Manually adjusting time (GPS Time selected): An offset can be applied to the GPS time. The offset is shown next to the time setting.
CLOCK
