oil in air cleaner on 2017 streetglide
I am running oil level at half way mark on dipstick and i still get oil in air cleaner and oil level goes down because of this. I am going to bring bike into dealer for this and was wondering what they will do to to determine the cause and what would be the fixes. And if oil level is correct at half way mark why don't they make that the full mark. I feel you should be able to keep oil at full mark and no problem with oil in air cleaner. Thanks
first Harley?..wish there was an easy answer..those breather bolts are designed to spew into the AC..more so in Summer and riding hard..working as designed..unfortunately
I'm just going to throw this out here, may help, may not. My bike when new just puked oil out of the breather. 500 mile service I pointed it out, cleaned the filter and told me that maybe I was lugging the engine, to always stay above 2500 rpm. What? Flat out told them that I run it hard right from the start so if it does break it'll be on their dime.
Anyway 100 miles later, same thing. Oil spewing out of the AC. Took the filter out to clean it and noticed that the molded rubber breather tube was sort of kinked. It is very easy to kink the tube installing it! I made sure it was routed through the filter correctly when I put it back together. Not a problem since! Fill it right to the top, lug it, redline it, nothing.
So, coincidence? Maybe, maybe not. I'm just throwing ideas at you.
jerseyjeff62 (08-10-2017)
I got sick of oil coming out of my Road Kings airbox . Some guys will run the breather to the ground rather than the way HD does it. I went old school and took an empty 6.4 oz container I had and fashioned a catch for the oil. It fits snug in the airbox. Rode 120 miles today and no mess.
No problem. Like I said it doesn't hurt to share experiences. Good luck figuring it out.
