Is top speed limited?
Old 07-26-2017, 09:16 AM
TomcatCV62's Avatar
TomcatCV62
TomcatCV62 is offline
Originally Posted by tyrant33
We can start an oil type debate.
Mobile 1 in the engine, Redline with shockproof in the tranny, and Harley Formula Plus/ Redline with shockproof in the primary.
Old 07-26-2017, 09:46 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,609 Likes on 2,727 Posts
Originally Posted by BrandonSmith
There IS a speed limiter. It cuts out at 110 regardless of being in 5th or 6th gear. Since there are different gear ratios, the RPMs are different, yet it cuts out at the same speed. Therefore, there is a speed limiter.
Ah, ok, well, my bad then.
Old 07-26-2017, 10:02 AM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Veteran: ArmyVeteran: Navy
Received 6,579 Likes on 1,814 Posts
Not on an M8!- at least not until they have a solution for the trans to primary oil transfer issue.
Old 07-26-2017, 11:10 AM
cosarguy's Avatar
cosarguy
cosarguy is offline
Do you premix the Harley Formula and Redline with shockproof or just let the engine, transmission and primary do it for you?
Old 07-26-2017, 11:25 AM
TomcatCV62's Avatar
TomcatCV62
I let the 3 work it all out........ I was told, in the old days the guys would ride with a quart of oil with the shovel heads. Might have to do it with the M8's too. I have yet to notice the tranny fluid migrating into the primary, I only have 1000 miles and havent ridden much since the 1000 mile. I will be checking all the time now. Im not to worried though, it is what it is.....
Old 07-26-2017, 12:44 PM
103Eagle's Avatar
103Eagle
103Eagle is offline
Originally Posted by Keithhu
They arent speed limited, they are rev limited. Stock is 5500 I believe, most aftermarket tuners can take it to 6200
Not completely correct. They are mph goverend and the stock rpm limiter is around 5400rpm. With the Harely EPA tuner, your rpm limit is raised to around 6200. Other tuners can offer different speed and rpm parameters.
Eagle Out
Old 07-26-2017, 12:48 PM
mchertel's Avatar
mchertel
mchertel is offline
Complete stock CVO Limited and had it up to between 115 and 120. Maybe it was the tail wind that gave me the extra few MPH!!
Old 07-26-2017, 12:55 PM
103Eagle's Avatar
103Eagle
103Eagle is offline
Either that or maybe you ate BEANS before your ride!
Eagle Out
Old 07-26-2017, 08:02 PM
rjmac53's Avatar
rjmac53
rjmac53 is offline
The true speed limiter on the Harley is the poor performance!!!!!
2011Deluxe
01-26-2012 10:48 PM
TVtommy
09-21-2009 12:08 PM
EMASON01
05-06-2008 06:53 AM
mbjam359
12-27-2007 04:23 PM
ATM67
Shovelhead
08-27-2007 05:01 PM
Quick Reply: Is top speed limited?
