Oil light came on
Oil light came on
I was heading home last night after stopping at a bike night. Started up the RG and pulled out. noticed that my oil light came on. checked the oil pressure and it did not register just a dash instead of the usual OK.
pulled over and shut the bike down. turned the bike back on and started it again and everything was a-ok. came home, no issue, oil sensor showed the usual ok. Got up this morning and started her up this morning and no issue at all. the bike did not sound like it was starving for oil or that it was running hot. I will check the oil a little later (when the temp in the garage drops below 100 degree's). my thought an interment failure of the oil sensor. I will tell the dealer the next time I am in there or if it does it again. couldn't get the failure to repeat.
anyone else experience this
That's exactly what I figured. I was thinking the sensor may be failing. at any rate, next time in to a dealer, I will have them check it out.
