Get a Grip, will ya?
One thing that bugs me about my '17 SGS, aside from the fact my recall notice came today, is the OEM grips HD installs. I'm not a big guy, but my hands wrap around the OEM grips and then some. The same thing happened on my '13 FXSB. Most of the grips I see aren't much better. Harley used to offer a set of foam grips (#56006-88C) for cabled throttle bikes, but they discontinued them. I bought a set for my FXSB, and they were fine - thicker than the OEM or most aftermarket grips. I did some research and found that those foam grips were really Drag Specialties "Sundance" grips with an HD end cap that jacked up the price 110%. Also, they have a version for TBW bikes too, and replacement foam. So if you've been looking for larger grips:
Cabled version: #DS-243122 $23.95
TBW version: #0630-0591 $23.95
Replacement foam: DS-243125 $7.95
OEM Grips: 1.375" Dia. (4.32" surface)
HD "Get-A-Grips": 1.57 Dia. (4.93" surface)
DS "Sundance" Grips: 1.77" Dia. (5.56" surface)
(So with the Sundance grips you get an additional 1.24" of surface.)
psyshack (06-19-2017)
I've had a set on my breakout for almost 3 years now, and while the foam is a bit stiffer they're still in good shape. Besides, replacement foam is only $7.95 a set at any Drag Specialties dealer. (#DS-243125)
I've got a pretty bad case of carpal tunnel syndrome, so anything I can do to lessen vibration helps. I ordered a set of these:
https://www.markscustomdesigns.com/p...ng-grip-covers
They look a LOT better than the foam things, add some circumference, and dampen the vibration (a little).
