New M8 stage IV
Old 01-01-2018 | 09:18 PM
$tonecold's Avatar
$tonecold
Originally Posted by JWSRG
Do the cam anyway. I have the stage 4 with a TTS mastertune and sent it out to a tuner. Only 119 hp and 112 lbs of torqe at the rear wheel. I believ e Harley's numbers are at the crank not the wheel. Its false advertisement. I'm doing a Tman 226 CAM or the SE 447 and a Fullsac header and 2.0 baffles. Forget the warranty. The bike is gutless unless I'm in the range of RPMs where I'm getting 27 miles to a gallon. Check out Fullsac Performance. He has played around with the stage four and using the different Cams to get the torqe all the way across the board. I believe he hit 130+ lbs of tourqe with the 447 cam. Although Harley doesn't recommend it I say the hell with it I want a bike I'm not redlining all over the place just to have the power. Below is a snap shot of what Fullsac has on their page.
[img]webkit-fake-url://ce0f75d2-e02f-48eb-8fbc-83eda703e0cb/imagepng[/img]
I’m not sure how much compression the stage four is pushing, but the 447 cam might build very high cylinder pressure. This could make for a good looking graph at full throttle, but could make the bike not very streetable. I’m talking about detonation when accelerating under a load. The four valve head is a different animal and may be able to handle a lot of cylinder pressure without detonation. It’s like Steve Cole says, that dyno graph doesn’t tell you about driveability.
I do know where you’re coming from. It’s the reason I really liked what I saw when Fuelmoto put the wm8-22x in a stock CVO 117”. Just remember that the stock 117” is only 10.2:1 compression. Even with that compression, with the 22x the intake valves are closed at 22 degrees abdc and it develops 217 psi cylinder pressure at sea level which is the same as the M8 107 with the stock cam. I would bet that this is a very streetable combination.
  #52
Old 01-04-2018 | 09:15 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
The factory 117 Stage IV kit is rated at 11:1 compression ratio. We recommend the TTS 200 cam for that application. Attached are the results of just that build and with ~115 ft lbs @ 1700 I do not see the need for much more on a street bike.
The following 3 users liked this post by Steve Cole:
Bannana Boat (01-06-2018), High Octane (04-18-2019), Woodsy (01-11-2018)
  #53
Old 01-06-2018 | 06:03 AM
Durwood 1's Avatar
Durwood 1
Impressive.
  #54
Old 01-26-2018 | 02:11 AM
badcooky's Avatar
badcooky
Originally Posted by Durwood 1
Impressive.
Yea man.
  #55
Old 01-26-2018 | 10:19 AM
Kay9Cop's Avatar
Kay9Cop
That's an impressive chart.
  #56
Old 01-27-2018 | 03:31 PM
Indyultra's Avatar
Indyultra
Had my stage iv done this past summer, 125hp 116tq. With fuel moto full exhaust.
  #57
Old 01-30-2018 | 10:47 PM
badcooky's Avatar
badcooky
What is your opinion of the kit ?
Do you have a dyno graph ?
  #58
Old 05-08-2018 | 08:11 PM
redtwin's Avatar
redtwin
Originally Posted by LoneWoolf
Did you get a written guarantee that your Dyno numbers would be identical to the numbers that they show on their website?
Nobody does but it should be close,I at least got 122 hp and 114 tq,Road King Special stage 4 SE high flow W/Street canons with cat removed from the muffler and TTS master tune
Before muffler mod and getting rid of the se tuner was 115 hp and 113 tq,Both at the same dyno and tech doing the tune and in SAE not STD
Also the speed limiter came in at 105 mph wich means a stage 4 would only work about a third of the way through 4th gear and its done
  #59
Old 05-08-2018 | 08:15 PM
mjwebb's Avatar
mjwebb
Originally Posted by sixguns
I'm giving it all she's got Captain!
Damnit Jim, I'm a Parts guy not a Mechanic!
redtwin (05-14-2018)
  #60
Old 05-09-2018 | 09:17 PM
Wmoor004's Avatar
Wmoor004
I dont know what to tell you except that it took about 5000 miles for my stage III to loosen up and run like it does now.
It only took me 2000 miles and TTS 200 cams and she runs like a best.
Quick Reply: New M8 stage IV
