Smart tune recording
I have completed 1 Smart Tune back in early March or so. I am not sure if I really meet all the criteria suggested by Harley as far as RPM, length of time etc. etc. Also don't have a closed track as they suggest to perform these on. My question is what do I really need to do as far speed, length of time etc.? It's warmer out so I thought it might be a good time to get another smartune done, plus I am at 2k now as where the 1st one was done still during break in.
My opinion...........
First off since you are not sure about your previous tune and your record session was prior to break in, I would start over. Load the Stage 1 map like you did the first tiime (or whatever calibration matches your bike). Then do a fresh data recording session. Make sure you save the sessions with either a date/time or Tune 1, Tune 2 etc. so you can load them properly. Once you get the new data session, follow the rest of the procedure for a NEW CUSTOM CALIBRATION. Also consider what I wrote below..........
Warm up your scoot first, start recording data, take a nice ride, like posted DO NOT CRACK IT OPEN OR DUMP OUT , ROLL THE THROTTLE. Now ride at different speeds and conditions. Ride it and let it record all it can (red light flashes quickly). Then follow the instructions on how to download the data. I believe the instructions mention if you don't have a closed course, ride at speed intervals of 10mph and hold the speed for 10 seconds while recording. Just vary the throttle positions and speeds is the important thing.
Once you have done the first tune and allowed the software to do its thing, do a few more record sessions and let it continue to adjust. You can record and adjust to you feel its running right or you see no cells being changed when you compare data. I have done 3 tunes so far and plan on doing more. I don't worry about being precise, just taking a ride with different throttle conditions and speeds. We can only adjust a small amount with the EPA conditions set in the tuner. I can't say that I have noticed a major difference in how it runs although it should help fuel economy and response from the canned starting map. It does seem that the small amount of decel popping is completely gone now. Hope this helps!
Eagle Out
Eagle Out
make sure that you are saving the recorded runs and are using the last saved file to perform another smart tune session. Each new session begins with the last saved session/file. Do not start with the same original file otherwise you are running in circles and will not get the benefits.
kingkingking
08-07-2011 09:42 PM
jluvs2ride
03-23-2010 01:14 PM
