who's been having to add transmission fluid?
Old 08-06-2017, 10:40 AM
Steve Helton's Avatar
Steve Helton
Steve Helton is offline
Originally Posted by Sam D.
Mine was 6 oz low when it was 2 weeks off showroom... Just did 1K and switched to Bel-Ray 85W140... keeping an eye on it with 1235.0 miles now.
How has your's done with the be-ray i just put that in mine.
  #942
Old 08-06-2017, 11:19 AM
Gamma742's Avatar
Gamma742
Gamma742 is offline
Originally Posted by bob2002
I wonder how much build date has to do with those affected? I want to take advantage of the good deals right now but it is causing me to pause.
Originally Posted by Gamma742
I put another 5K on my bike as we took a trip to Jasper Canada.. I saw no measurable transfer so I decided to put the bike to the test...
I rode up hill on Scripps-Poway Pkwy in 2nd gear for 4 minutes at 4700 RPMs (51 mph) then went home. The level in the transmission was the same. I learned that Cruise control works in second gear on the M8. I think on my old bike you had to be in third.
I was just over the 10K so I changed and measured the primary and the transmission.
I'm happy to say I am not one of the affected.
Also note that my build date is 9/16 as stated on the down tube.
Build Date has nothing to do with it!! I have an early bike and can't force it to transfer according to Steve Coles instructions. I think everyone that is concerned (all M8 owners) should run this test so they know for sure. All you need is an uphill grade.
  #943
Old 08-06-2017, 01:41 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
Mine's a pretty early bike too and I haven't been able to make it transfer any yet. I got it in Nov 2016. I'm wondering if maybe there was a bad batch of subcontracted parts at some point in the assembly history.
  #944
Old 08-06-2017, 02:26 PM
hattitude's Avatar
hattitude
hattitude is online now
Received 8,273 Likes on 4,442 Posts
That's happened a few times before (including cam plate debris on the M8), but first they need to figure out what is causing the problem to be able to single out a part issue...
It must be truly frustrating for those who are affected.....!
Luckily I don't NEED a new motorcycle. My '12 Limited is set up for me and runs great (stage II). I just really, really, really wanted to trade it for a new M8 Limited....
That won't happen until I see evidence the problem(s) is/are fixed..... just not worth it to me, to run the risk of getting an affected bike...
  #945
Old 08-06-2017, 03:30 PM
Billsbuffalo's Avatar
Billsbuffalo
Billsbuffalo is offline
I wonder how many other potential M8 owners are sitting on their money waiting for the problem to be solved before parting with hard earned cash?
If the MoCo were aware maybe it would spur them on to fix things!
  #946
Old 08-06-2017, 04:27 PM
Bill D.'s Avatar
Bill D.
Bill D. is offline
I'm one.
  #947
Old 08-06-2017, 06:35 PM
GTK's Avatar
GTK
GTK is offline
Originally Posted by Bill D.
I'm one.
And Bill,you will probably remain one along with Billsbuffalo and the rest of the non M8 owners who respond to this thread.
  #948
Old 08-06-2017, 06:45 PM
dDavid's Avatar
dDavid
dDavid is offline
I don't own a bike now, and I really, REALLY want a new Limited, too. I was/am hoping that they fix this crap in he 2018's! I would absolutely love to get riding before the season ends.
I don't want to pay $30,000.00+ for a motorcycle that stands a pretty good chance of just being pushed around to the Service entrance! With all of the different issues people are posting about it is very discouraging for potential M8 buyers. I'm not a savvy enough buyer to safely buy a used Limited, but I gotta say it is starting to sound like it might have its benefits over a new bike.
  #949
Old 08-06-2017, 06:51 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 9,375 Likes on 4,783 Posts
reality is, Vegas odds and all..you have a better chance at getting a good one, Motorcycle of the Year and all..than one with all the issues you read about here..they are Harley GOAT bikes..nor saying I don't understand folks having apprehension..but in the same breath they are missing out on fantastic motorcycles fearing the exception not the rule
  #950
Old 08-06-2017, 07:47 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
The only passageway from tranny to primary is the main shaft/clutch push rod. If you checked the clearance between the push rod and mainshaft bore on some of the bikes that are experiencing this issue, and some that are not; would there be a significant difference? Also, what does the inside of a main shaft look like, with respect to finish? Does the main shaft have spiral machine marks on it? Would some shafts have more cut or spiral than others? When hand reaming a piece, you let the reamer sort of screw it self through the piece, this can leave "rifling" marks, which could draw fluid through. If what ever vendor produced the main shafts and found the bore too small, I could see them sending back to be machined out further. I could be totally off base here because i can't even remember the last time I saw a Harley tranny apart.
Quick Reply: who's been having to add transmission fluid?
