who's been having to add transmission fluid?
#871
The OP was not on a dyno and many others have not been on the dyno. The dyno make it much easier to operate at higher engine speed, so I know that shows the problem much easier. The dyno is not the cause of the problem, its just a tool.
#872
#873
I spoke to the guy doing the work on it and he told me most of what he did per the email HD corp sent them. The vent system was check by pushing compressed air into the the oil fill and checking airflow out of the vent hose, Clutch slave removed check the rubber seal on it for cracks. Then remove the vent cover plate and check gasket sealing and replace gasket. While vent plate remove inspect some passageways. Remove clutch pushrod and inspect mainshaft hole for obstructions. Open primary and check torque on Clutch basket and engine output shaft. Remove the primary chain and pieces to replace main seal and the sleeve it rides on, reassemble. With all that done give bike back and have customer return for level check every 100 miles. Result, one day riding through the mountain roads about 80 miles the transmission dipstick is dry. So back to the dealership it goes.
#874
Put 300 miles on my after they did the inspection work. When it cools down I will pull the primary cover and check.
If all you are doing is pull trans dip stick chance are you will not notice a couple OZ migration. I did not really notice it on mine until I started check the primary level.
#875
#876
No and the screws do not run through. No big big to open it. I let it cool so that each time I check it is at the same temperature. Just came back in it is normal right now. Keep in mind it took 1350 miles to show the transfer last time. I will keep checking . If Doc say wife can ride we put some miles on this week end.
stixvrad (08-02-2017)
#877
What hasn't been documented or commented upon is 3k to 4k rpm operation at extended lengths of time.
I just got home from an 1100 mile trip to Sturgis and back. Stay tuned for my report on oil transfer during this trip....
#878
I put another 5K on my bike as we took a trip to Jasper Canada.. I saw no measurable transfer so I decided to put the bike to the test...
I rode up hill on Scripps-Poway Pkwy in 2nd gear for 4 minutes at 4700 RPMs (51 mph) then went home. The level in the transmission was the same. I learned that Cruise control works in second gear on the M8. I think on my old bike you had to be in third.
I was just over the 10K so I changed and measured the primary and the transmission.
I'm happy to say I am not one of the affected.
Also note that my build date is 9/16 as stated on the down tube.
#879
If you were to use the same oil in the trans and primary and let the transfer continue , just adding oil to the trans as needed. What could happen? How far overfull would the primary get and what would be the net result if it happened? Basically say eff it and let them both seek their levels? And in NO WAY am I suggesting its an acceptable solution. Just simply asking people who know way more about HD's then I.
#880
