who's been having to add transmission fluid?
#471
#472
#474
Or maybe coat the innards and let the oil flow wash it off showing flow. Goofy idea but how else would we know what goes where?
#475
I wonder if something could be used to coat the inside of the trans and reflect heaviest oil flow route to the transfer site? Might be too much spraying and fog for that.
#476
Seems the MoCo could 3D print a clear cover & watch?
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
mjwebb (07-02-2017)
#477
Gary
#478
Just flashed on me! You know that clutch handle "wobble" felt when modulating the throttle?
That's the push rod going back and forth due to the new trick clutch. Quite a bit of "endplay" feel in the lever. I believe that back and forth pushrod action can act as a fluid transfer pump.
At prolonged high rpms transmission oil temps elevate in turn, create pressure and windage which feeds the pump.
TC trany pushrods (clutch) don't move back and forth and don't have the fluid transfer issue.
My thoughts,
Bob
My thoughts,
Bob
#480
I have, about 3 time now. You just don't understand it .. The movement of the rod is asymmetrical.. It acts like a pump..
Add: Spray coats the rod or even the level in the cavity is slightly above the lower hole in the mainshaft for the pushrod.. Based on the rate you are saying the level changes there almost has to be a pump..
Sorry but you have not answered it yet again. The rod moving back and forth(if it does at all) will not pull oil from the case up hill over an air gap. It may move what ever is in the tube back and forth but you still must overcome the fact that there is no oil path there to start with! There is air around the pushrod in the tube. The ONLY way your rod movement works is if the rod is open to oil flow.
Solve the oil flow and the problem goes away, as rod movement has nothing to do with it.
