who's been having to add transmission fluid?
#321
when checking mine periodically it's been dropping from Full to Add level...now granted the diff between the two is only a couple ounces tops..but my Rushmore was pretty much set it and forget between ~10K fluid change...I'm at 6 K now and since the 1K I've had to top it off a couple times..something to check regularly now which hasn't been all that necessary on past bikes
#322
Yes and to add to the confusion.. used to check it with the dip stick resting on top of the threads not screwed down to the O-Ring.
#323
It cracks me up that HD uses a dip stick that's all but impossible to read clearly, and uses the method you pointed out. Can they make it any MORE vague? I must have checked mine ten times to make sure I was seeing it right.
#325
If it is, its very minimal. Toss in that the trans is actually over filled and I don't think there's anything going on. I guess proof will be if I check it down the road and the primary is any higher than in the photos. If I bother to check it at all that is.
#327
#328
Just got back from the dealer. I told him what was going on and the pictures I had from my trip. He's telling me there's no way that could happen. Well, I'm bring the bike in Monday. I asked him what their going to do. He said they'll have to call a tech and go by there recommendations. I'll let ya know what happens.
#329
Macrunner (06-29-2017)
#330
Unfortunately for me I have another issue going on so my testing stopped at 600 miles.
