who's been having to add transmission fluid?
Old 03-10-2018, 05:27 PM
tbob's Avatar
tbob
tbob is offline
If they were all doing it it would be a easy fix. Any machined part has to be checked and lot numbers production dates and so on. Logistics would be a nightmare.
  #2782
Old 03-10-2018, 06:02 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,690 Likes on 1,671 Posts
Originally Posted by $tonecold
I just got my 2015 RG back from being dyno tuned yesterday. Was getting ready to take a ride today and decided to check fluids before taking off. The transmission fluid wasn’t even on the stick. I don’t know how much it will take to bring it up to full since I didn’t have any transmission lube to add. So I now know I own two Harleys with the transfer problem. Looks like I’ll be getting another side cover machined for a seal.
Well if the fluid fresh and the same in both holes, just move it back to where it belong!
  #2783
Old 03-10-2018, 06:51 PM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,854 Likes on 1,001 Posts
Yeah, that won’t work, I use Redline. I may put some Formula plus in until I see if the different pushrod is going to solve the problem.
  #2784
Old 03-10-2018, 07:28 PM
not a sock's Avatar
not a sock
not a sock is offline
What are we to do, install a valve to drain oil out of the primary and pour it into Trans?
I didn't pay all of the money I did to 'oil change' in a parking lot...........
  #2785
Old 03-10-2018, 07:45 PM
tbob's Avatar
tbob
tbob is offline
If mine was as bad as yours I would drain the tranny put it in the primary and
let it idle in the drive until it comes apart. And I would do it every time they sent it back without a problem.
  #2786
Old 03-10-2018, 09:02 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Nor have I, but I just cannot knowingly allow it to run dry except when told to by the dealership! I found I can remove the drain plug and simply reinstall while watch the Primary level. Catch the oil in a clean drain pan, then pour it back into the transmission. No it's not the correct thing to have to do but it does work.
  #2787
Old 03-12-2018, 07:06 AM
TomcatCV62's Avatar
TomcatCV62
TomcatCV62 is offline
Im not even going to pretend that I know as much as some of the fine folks here on the Forum. What I do know is, I work around rotating high speed equipment, i.e. , pumps, blowers, generators, and when I was in the Navy... turbines. That being said, I think, when the transmission fluid moves to the primary, there is a point where they equalize. At this point, there is still enough oil in the transmission to keep it lubricated. This is just my opinion and a theory at best. It makes sense, or we wouldve heard about a tranny burning up while it is going down the road. Then we wouldve had a recall........ You can bet your bottom dollar that the MOCO knows this too. Like I said, this is just my opinion.
  #2788
Old 03-12-2018, 11:42 AM
Retrop's Avatar
Retrop
Retrop is offline
I think I heard Steve Cole say once that he got his transmission hot enough with a low supply of oil that it was beginning to make a little noise and was tightening up. Perhaps he can confirm this.
  #2789
Old 03-12-2018, 12:49 PM
SoCalHDMC's Avatar
SoCalHDMC
SoCalHDMC is offline
3700 miles on the primary oil.
A bit overfilled if the details matter (they definitely do to me), but I did not do the 1k service, so theoretically it could have been this way since the service. If it is pumping anything into the primary I would tend to think it is engine oil, as the trans. level has not changed (at least not that you can see on the X of the dipstick) in the same 3700 miles, and the engine does eat a little oil.
Going to sample the trans. and primary to see what difference in makeup I can find (excluding clutch material) between the two.
  #2790
Old 03-12-2018, 02:16 PM
$tonecold's Avatar
$tonecold
Is the bike straight up or on the side stand. It has to be straight up to check the primary.
Quick Reply: who's been having to add transmission fluid?
