who's been having to add transmission fluid?
Old 02-08-2018, 06:46 AM
TomcatCV62's Avatar
TomcatCV62
TomcatCV62 is offline
I havent checked this thread in quite a while now. From what i gather, there is a fix? can someone point me in the right direction please, how far back is it? Thanks in advance.
  #2692
Old 02-08-2018, 07:50 AM
harleytuner's Avatar
harleytuner
harleytuner is offline
If there's an official fix I missed it.
GPHDXLC (02-09-2018)
  #2693
Old 02-08-2018, 07:37 PM
TomcatCV62's Avatar
TomcatCV62
Ohhh, thought there might be....... it’d be nice if there was.
GPHDXLC (02-08-2018)
  #2694
Old 02-09-2018, 12:02 AM
Retrop's Avatar
Retrop
Retrop is offline
You are probably referring to one of the faithful posters here who machined a nut that fits on the end of the clutch push rod tube leading from the transmission to the primary. He seems to be certain that at the very least it will slow down the fluid progression. It looks like it might work but he has not reported back since he put it all back together. Probably a cold weather holdup. It is not a complicated fix so I wondered why has the MOCO not thought of it yet? Maybe they have and were not sold on the fix. Who knows for sure because the MOCO does not share Jack Squat with their customer base. I did read yesterday where the Federales are forcing the MOCO to have another recall to fix the ABS brakes system on bikes going back 6-8 years. This one has to do with the fact owners are not changing out their brake fluid every 24 months like the manual says. This recall will further add to their continuing financial woes.
  #2695
Old 02-09-2018, 10:24 AM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,854 Likes on 1,001 Posts
I have not installed the seal and nut on my bike yet. I hope to do it next weekend. It should fix the transfer problem, if it just slows it down the seal is leaking.
One thing I am interested in is the kit that the MOCO is coming out with that was mentioned by pappshelby in post 2689. I am not going to delay installing the seal because of it, but I am curious what it is. So far everything the MOCO has tried has not worked in every application. Maybe this one will.
FM500 (02-09-2018)
  #2696
Old 02-09-2018, 07:16 PM
artsbest's Avatar
artsbest
artsbest is offline
Sumping issues and trans oil leaking into the primary. Two problems I keep reading about with the M8 engine(s). I am not a mechanic but one must ask HOW is HD getting away with this? I mean this is 2018. GM held info about that switch that ended up killing 123 people. To replace the switch it would have cost $.57. Nobody has posted any injury due to this leaking oil which is probably why HD is NOT addressing this problem head on. I was about to order a 2018 HD Fat Boy end of this month. Now I have second thoughts.
GPHDXLC (02-10-2018)
  #2697
Old 02-10-2018, 08:51 AM
Gamma742's Avatar
Gamma742
Gamma742 is offline
They probably copied what you fabricated and are working on patenting it now.
  #2698
Old 02-10-2018, 11:00 AM
$tonecold's Avatar
$tonecold
One can only hope, I think it is the only positive sure cure for the transfer problem. I want those affected to have their problem solved. After all, imitation is the sincerest form of flattery. They can claim it as theirs, but the forum will always know the truth.
The following 2 users liked this post by $tonecold:
FM500 (02-11-2018), Gamma742 (02-10-2018)
  #2699
Old 02-10-2018, 11:23 AM
pappashelby's Avatar
pappashelby
pappashelby is offline
I just hope they have a real cure. Going cross country in April. Can I stop at any dealer and have them top it off every 1k miles under warranty ! I'm not a happy camper
  #2700
Old 02-10-2018, 11:54 AM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,690 Likes on 1,671 Posts
I was told to bring it in every 500 miles for checking. How you going to find a dealership every 500 miles and who's to say how long your going to have to wait at each dealership? Pretty much ruins the entire idea of getting out and enjoying the ride.
The following 4 users liked this post by Steve Cole:
103Eagle (02-12-2018), 14GuineaPig (02-10-2018), FM500 (02-11-2018), pappashelby (02-10-2018)
Quick Reply: who's been having to add transmission fluid?
