who's been having to add transmission fluid?
#2311
It was full after the service, always double check certain things..I did check service manual and yes, it says check on jiffy stand..Ill do that and see what it says..thanks!!! and duh!!!
Checked on stand and it was good to go...phew..sorry guys!!!
#2312
You said in post #2303 you checked it on the side stand which is the jiffy stand and it was low on the stick.Now you check it again and its OK.I think that because the oil is so hard to read on the trans stick,a lot of owners misread the oil level.
mastergunnera8 (11-10-2017)
#2313
You should check it on the jiffy stand and it should be cold. It's good to see you don't have a problem. I don't think we'll see many 14-16's transferring. Something they did to the '17 transmission has made this more common.
#2314
#2315
Well apparently and I am not privy to any knowledge that is not common, the transfer in the 14-16 models stems from them having a leaking engine mainshaft seal that draws a vacuum on the primary. I think the MOCO assumed when they started having problems with the '17 models that the cause was the same and it may be, but replacing the seal and spacer in the '17 models doesn't seem to cure the problem. It apparently did cure the problem in the earlier models. This is of course just conjecture.
#2316
I'm by no means mechanically inclined, but it cant be that hard for harley engineers to figure out. I'm sure their making close to 6 figures a yeah each. Earn that money!
Or....is it as other's have speculated here. They know the culprit, but its too expensive to justify doing right by their customers and standing behind their product/mistakes.
#2318
all my bikes shifted MUCH better without 3-1 in the tranny.
plus, why pay to put synthetic in all 3 holes? esp if it is just pouring out the other side
remember how older high mileage cars would LEAK synthetic if you switched, but not leak Dino oil, because it is "bigger"? could using synthetic be part of the problem? what comes in the tranny from the factory?
didn't someone say using the Formula+ makes it stop transferring oil?
FWIW, pull the dip stick, and lay it on a napkin/rag that is clean, and the dampness from the oil should show on the rag, then compare the rag to the marks on the dip stick.
#2319
If not for the transfer issue I'd probably use Mobil 1 85W-140 in the trans.
04ctd (11-11-2017)
#2320
Thank you sir! I used Mobile 1 for the engine and used Bel Ray 80W for the transmission when I hit 5,000 miles but I haven't changed the primary yet because I was missing a few tools at the time. I know I changed the transmission earlier then recommended but I thought it wouldn't hurt the bike and I wanted to flush the system early. But then with this issue I'm concerned about mixing the Bel Ray with whatever is in the primary. I'm going to switch to Formula 1 for the time being.
