who's been having to add transmission fluid?
#211
Some information is leading to there maybe more than one parts supplier and the issue is related to one supplier. This happen with a lot Indian's they had oil pump issues and turned out be be cases from one of tier suppliers.
Defective case supplied by one manufacture would explain some having the issue others not.
#212
Had the bike at the dealer approx 1000miles ago, complaining about the trans fluid moving into the primary. They drained the trans and the primary and filled it to the correct level. He said most probably it's the vent, but I don't know what he exactly did beside the oil change while I was waiting for the bike (they didn't let me in the shop). They worked on it for approx 1 hour and fact is, that since then no fluid left the trans. Strange.
FM500 (06-19-2017)
#213
Just read through this thread. Checked my dipstick per owner's manual. No fluid on it at all. Added about 10 oz or so of Formula+ and it's right at the middle of the add/full mark now. Put the bike up on the lift. Removed the derby cover and only got about 2-3 oz out with the bike level. Now I'm not sure what to think.
Bike has about 3200 miles on it. I let the dealer do the 1000 mile. Never checked fluids maybe they didn't fill the trans well enough but that seems unlikely. Weird that the trans was 10 oz low but the primary only 2-3 oz over.
Not sure of my build date (how do you check?) but the date will be very early. I bought the bike three days after they were released last August.
I'll be watching this VERY closely for the next few weeks. Man I'm glad I read the thread. Thanks to all who posted.
#214
We are all in suspense over this. You are not ready to let the cat out of the bag yet regarding where the problem is are you? My guess is that at this point it is all theory and you are going to keep testing until you can prove it before you announce to the world what the problem is.
Max Headflow (06-18-2017)
#215
#216
ocezam, I don't think you'll get an accurate overfill/transfer measurement determined by measuring what overflowed out of your clutch inspection hole when you removed the derby cover. Pull the drain plug, drain it into a catch pan, and measure exactly how much fluid you got out of it. I think you'll find the other 7-8 oz there. Try not to use the wife's good measuring cup tho, they frown on that.......
bomtek44 (09-22-2017)
#218
No problem...... HD of Fresno. Great group of guys over there and they have really taken good care of me. Even AFTER the original purchase, lol. JK, can't say enough about these guys, seriously.
#220
