who's been having to add transmission fluid?
#1401
psyshack (09-02-2017)
#1402
Thank God Harley does not make Airplanes,,,, Where did I read that? As your front brake rotors make you shake. OOO but there in spec for American made contracted junk. Your last tour you corrected me... All bikes on that run had a warranty issue.
#1403
The dealer checked your fluids and everything is OK? Yeah. I'm sure. Maybe YOU should check your fluids and see if everything is "OK".
There is no difference between the CVO primary/transmission and a 107" primary/transmission. If you really have one that isn't transferring fluid - great, but it has nothing to do with the fact that it's a CVO. I personally wouldn't take the dealer's word that everything is with in spec. You might want to keep an eye on it yourself.
ocezam (09-02-2017)
#1406
I'm remaining subscribed in hopes of reading of someone's success with this.
Mr. Cole, thank you for your efforts and sharing the results. FWIW, eventually I'll be picking up a good tuner (post warranty) and your TTS will be first choice. Like the folks at Baker Transmissions you're good at pointing out legitimate problem areas and finding fixes. Sometimes.
#1407
I was just messing' with ya'..believe me I'm not happy with the QC at all..they'll NEVER be Yamaha in that regard..wife's clutch switch, the one already replaced under warranty fails starting in gear intermittently, and failed in front of the service writer who even admitted they've been seeing problems with them, so he checked it in, next day when tech did his thing and it worked so they said no go, it will have to fail during the 'official inspection' to be replaced again under warranty..so now we're faced with trying to time the failure and get lucky with them...what a total load of crap
#1408
#1409
The following 2 users liked this post by bob2002:
jamala00 (09-02-2017),
Steve Helton (09-02-2017)
