who's been having to add transmission fluid?
Old 08-26-2017, 05:24 PM
Blue Tick's Avatar
Blue Tick
Blue Tick is offline
Ok I'm going to wade into this thread. I haven't read the whole, but I'm about to start. So my '17 RGS was bought in May. The dealer had installed the stage 2 kit. I've been hearing a lot about this and went and took a look. On the stand, garage temp if there was fluid on the dipstick it was at the bottom of the X. Cracked and ran it for about 5 minutes with the same result and a little trash on the magnet. Take a look at these 2 pics and tell me what you see.
Cold
Ran for 5 minutes.
  #1312
Old 08-26-2017, 05:45 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,018 Likes on 4,065 Posts
Looks good.
  #1313
Old 08-26-2017, 06:10 PM
MotoJockey's Avatar
MotoJockey
MotoJockey is offline
Received 3,273 Likes on 1,342 Posts
The only thing I see is that you bite your nails..
LMFAO!!! Dude! That's the funniest **** I've read in a very long time! Thank you sir!
  #1314
Old 08-26-2017, 06:20 PM
Max Headflow
That may have been a little blunt on my part..
  #1315
Old 08-26-2017, 06:28 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,481 Likes on 761 Posts
Level is good, thats where it should be. the junk in pic two, what is it? I did not know the stick was magnetic.
  #1316
Old 08-26-2017, 07:23 PM
Blue Tick's Avatar
Blue Tick
LMAO......that's what 12hrs of hurricane shifts will do to you.
04ctd (08-27-2017)
  #1317
Old 08-26-2017, 07:58 PM
Blue Tick's Avatar
Blue Tick
Just a small piece of trash that stuck to the stick. I'm guessing it's magnetic as it was stuck to it.
  #1318
Old 08-27-2017, 01:20 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,690 Likes on 1,671 Posts
I know a lot of you are waiting on this so here it is. Our customer enjoyed his vacation and did not add any fluid to the transmission for the entire trip with the modifications I did. Trip was about 5000 miles, so going from having to add fluid every 200 - 300 miles because nothing showed on the dipstick to making this entire trip, he was happy with the results.
Is the problem fixed, NO. we still had a small amount of transfer. Both the primary and transmission were drained and measure and as before the missing fluid was in the primary. So the results are much better than without the modifications but still not an entire fix.
The following 8 users liked this post by Steve Cole:
103Eagle (08-27-2017), dDavid (08-28-2017), FredCa (08-28-2017), hairymoth (08-27-2017), hattitude (08-27-2017), MotoJockey (08-27-2017), thereal142 (08-27-2017), YPD485 (08-27-2017) and 3 others liked this post. (Show less...)
  #1319
Old 08-27-2017, 06:08 PM
thereal142's Avatar
thereal142
thereal142 is offline
Sounds like close enough to a fix for me....what do I have to do? Forgive me in advance.....
  #1320
Old 08-27-2017, 07:38 PM
borrec's Avatar
borrec
borrec is offline
Add another bike to the list. Did my 5,000 mile service and sure enough the Xmsn was down to the middle of the marks. I had it about half way between the middle and full when I noted the level last. Opened up the primary and that is where it went. Off to the dealer this week then.
Quick Reply: who's been having to add transmission fluid?
