who's been having to add transmission fluid?
#1272
I pushed mine into 4500 and 5000 RPM for auto tuning for sustained 5 second count like the screaming eagle software literature required. Multiple times to simulate multiple load/MAP values. This is where I experienced about 4-5 ounces of transfer. The point is it shouldn't be happening, period.
and yes, some of us riders do run them hard on the interstate when guys want to roll.
It's not a Hayabusa, I know, but I'm gonna get the needle pegged to see what she's got.
Harley needs to have done their homework, bottom line.
smitty901 (08-22-2017)
#1273
I ride most of the time in the 2200-3000 rpm range and sometimes when I get a hair up my *** I like to rip through the gears and hit the rev limiter now and then. You can ride these bikes long and hard and not hurt anything except maybe your old bones.
I agree the oil migration should not be happening and I'm keeping a close eye out on mine. Still not sure if my oil is transferring..
#1274
TomcatCV62 (08-24-2017)
#1275
#1277
The following 4 users liked this post by Michaelpost:
#1278
Michaelpost, are you sure they're pulling and replacing your tranny? And in only 4 hours?
#1279
The shaft seal and spacer that they are replacing on mine is on the crank shaft behind the compensator. They can do all the work from the primary side so they don't have to dive into the actual crankcase. They had to buy a "special tool" just for my bike to be able to pull the seal from that side. My bike has been at the shop since 8/2 when they picked it up and started the official HD Checklist. The seal is a stock item but the spacer is the magical part that doesn't seen to be in stock anywhere. Not exactly sure when that may show up but I hope it's soon........ Has anyone had they're seal/spacer replacement job completed? How did it go?
#1280
Yeah, I knew Steve had done one, I'm just wondering if anyone has had one completed by HD yet. A few of the guys mentioned that their seal was on backorder, like mine.
