Decel popping after AC and Exhaust Change
Old 05-05-2017 | 07:40 AM
GlidingJoe's Avatar
GlidingJoe
I too will try the suggested video. Thank you!!!
Old 05-08-2017 | 12:01 PM
StevieRay59's Avatar
StevieRay59
Update. I did the quick tune decell adjustment like in the video, problem solved. It was only 55 degrees out Sunday only heard one very slight pop sound in 100 miles of riding so I think it's good to go. I will see if it needs more when weather warms up here in Mi
Old 05-08-2017 | 01:40 PM
goose222's Avatar
goose222
It should get better as the temps warm.
Warm= richer, cold= leaner
Old 05-08-2017 | 03:21 PM
nikkolo's Avatar
nikkolo
6th Gear
Hi Stieve
Just to understand, but had you the decel popping with the KAT still present?
Currently I have only SE cannon 4,5 installed and I have no decel popping; I'm evaluating to install the SE Haevy Breather so is just to know if I have to expect to have decel popping and fix it with a further installation of a fuel tuner like FuelPak 3 or other.
Thanks
Old 05-09-2017 | 01:21 AM
StevieRay59
Originally Posted by nikkolo
Hi Stieve
Thanks
I changed head pipe and filter too. That's when I got the decal popping
Old 05-12-2017 | 06:46 PM
GlidingJoe's Avatar
GlidingJoe
StevieRay, did you have a chance to perform any Quick tunes? I can share that it did not help my decel pop after two adjustments/quick tunes as described in the video. Going to do a few Autotunes and a data log and get in touch with Jamie as he requested.
Old 05-12-2017 | 08:58 PM
StevieRay59
Mine got a lot better but I need to get some autotunes in also.
Old 05-13-2017 | 07:14 AM
GlidingJoe's Avatar
GlidingJoe
Can you share your final adjustments you made in QT
Old 05-13-2017 | 09:05 AM
prostar's Avatar
prostar
My popping happens when I don't roll off the throttle all the way between shifts and the engine is at normal running temps. I may try what the video shows. I have been trying to adjust my riding habits to do the complete roll of on the throttle but sometimes I fall back into old habits.
slowrollin
05-08-2016 07:16 PM
nickthecanuck
Exhaust System Topics
02-24-2016 11:51 PM
bettingpython
Fuel Moto / Jackpot Mufflers
08-28-2014 06:42 PM
jake40ma
2014-2023 Touring Models
11
05-31-2014 12:10 AM
hydrolock43
08-01-2010 05:57 PM
Quick Reply: Decel popping after AC and Exhaust Change
