Linked brakes with ABS
Who has them, and what do you think of them?
Are they linked, with just the "front"? And do the rears still work independently from the brake pedal? I can think of times when just the rear is wanted, like extremely slow maneuvers.
Has anyone had to do a hard brake maneuver in a turn, and how'd it go?
Thanks...
Thanks...
I guess it depends on your riding style. Most riders I've talked to like the linked ABS system, but I won't get it on my next bike (if it's still an option then).
ABS seems like a good idea since it normally stays out of the way unless you screw up. But the only time I felt it on my bike was when I pulled off the road to stop in a loose gravel turn-out. I was ready for a little slipping and sliding and for the tires to sink in a little. What I wasn't ready for was my brakes refusing to stop the wheels and nearly rolling me off the edge of the turn-out.
The linked brakes were one of the reasons I got rid of my '14 Limited. When I'd be heading into a turn and tap the rear brakes for a minor speed adjustment, the front end would dive because the linked system thought it would be better to hit the front brakes in case I wanted to stop and pick a penny up off the road. It made it too hard to trust that bike.
I'll skip it next time mostly because it's never come in handy for me, and in an emergency I don't like the thought of my bike second guessing me.
They will stop your bike a lot faster in a shorter distance that either regular or ABS. While some folks don't seem to like them, I think they're great. On curvy roads I brake before I get to the turn and if I don't I can still ease a little front or rear brake on.
If you have really screwed up and fly into a corner, way to fast, they could save your life.
First time I've ever had them on a bike. I really like them and I have used them. In at least one incident, they probably kept me from going down when a lady turned left in front of me. My only option was to stand on the brakes, and the bike just stopped, all the time I felt very much in control (although, I don't think I was!).
Anyway, gets my nod.
Like them just fine. Don't have to move my foot to the brake on the highway.(improves reaction time slightly)
Above 25 mph, either brake operates both. Out of habit when applying both I can feel
how the hand brake feels different based on how much you apply the rear.
Even if you do as is normal applying both, the ABS assists in minor adjustments/corrections and probably what
you are feeling in the hand brake I can feel a difference in the foot as well that changes as your pressure on the hand brake changes.
The only caution is........if only using say the hand brake and you keep it applied from say 35mph until you stop it stays linked.
If you use the hand brake only and release it below 25 mph and then re apply it, you only got the front brake and it will feel different and
could be a surprise if you happen to hit a little sand of slick spot.
If you change wheel size or tire size it will affect the ABS, Even changing brands of tires could affect it as other brands are not gonna be exactly the same size as stock.
