I fitted new bars today but unfortunately broke a ribbon inside the right hand side switch, part no 4 on the enclosed diagram, does anyone know if that can be replaced on its own or would I need to get a complete switch pack ?
I wasn't sure if it was for the lower buttons that aren't used on the road king but when I put it all back together the front brake switch is not working now.
Best bet is to call your local parts department. Usually if they have a separate PN, that means you can order just that specific part. Hope this helps.
Yep, stripped the switch down this morning & although the jumper is listed as a separate part theirs no way it's coming out so looks like a new switch pack !
This thing is so delicate & no way repairable, if it was a normal wire no problem.
Having checked the price of a new switch pack it turns out I can get a pair of new illuminated switch packs for the same price ?? Only listed up to a '16 model but look the same to me.
Crazy with what they can get away with. I ordered an AC cover the other day from HD, covered arrived, no hex bolts, no medallion, $30.00 later and I had what I thought was included.
I know its crazy, i ended up paying £225 for a replacement switch pack this morning & thats with discount, turned out to be an expensive bar change.
I swapped out my black for chrome and have both sides in a box. Not sure if they are interchangeable, but I'll make you a heck of a deal if they are. I have a 17 RGU. PM if interested. They have less than 100 miles on them.
Thanks for the offer, much appreciated, but yours will have extra switches on the bottom whereas the RK doesn't.
