Brandon's 2017 FLHX
Old 12-25-2018, 08:42 PM
barneyboy's Avatar
barneyboy
barneyboy is offline
Received 2,763 Likes on 1,598 Posts
Glad to hear from you again! It's been a interesting journey thus far, and I appreciate your sharing. Looking forward to more, good or bad.
BrandonSmith (12-26-2018)
  #242
Old 12-25-2018, 11:34 PM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 3,094 Likes on 1,831 Posts
Originally Posted by nobodyknowsme
Apparently I have really been missing out on a fascinating thread.
Sarcasm is hard to sniff out online lol. But I wouldn’t go that far to say it’s fascinating... When I started this thread, the idea was that I’d just have this space to log any changes to the bike, etc. I didn’t really think anyone would read it or care about what the hell im doing. Apparently mundane things are interesting to people.
  #243
Old 12-26-2018, 10:29 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 9,309 Likes on 4,753 Posts
glad to hear you kept your bike despite whatever troubles you're facing and hope they are just temporary and things work out for you and your family..totally understand the 'gotta' do what ya' gotta' do' aspects of life..but I know I would have to hit rock bottom last resort to entertain quitting riding cuz for me since I was a kid it's always been
BrandonSmith (12-27-2018)
  #244
Old 12-26-2018, 10:30 AM
Magnut1's Avatar
Magnut1
Magnut1 is offline
Received 1,723 Likes on 842 Posts
Hey Brandon, it's me, your Dad's friend from Toledo. (Tracy). If those street cannons are rattling around, they might be easy to repack like CVO mufflers. Pull the end cap and see if there are 2 spot welds holding in the baffle. If so, you can take a die grinder, grind the weld blobs off and slide out the baffles, they are wrapped with a heat resistance pad and wire tied together. They get blown out from use. You can leave the matt out and it will be somewhat louder. Hint: I used a broom stick shoved in the inlet and pounded the stick on the driveway, pushing the muffler out the outlet side.
  #245
Old 12-27-2018, 08:08 AM
BrandonSmith
Thanks, MJ. It was tough to even consider selling. And it was a little more tempting to look at downsizing from the street glide.
  #246
Old 12-27-2018, 08:11 AM
BrandonSmith
Thanks for the info, Tracy. The issue I have with the street cannons is that the baffle breaks loose and rattles around. When you break the welds to repack it, are you welding it back together? Or just leaving it loose?
  #247
Old 12-27-2018, 01:02 PM
Magnut1's Avatar
Magnut1
Magnut1 is offline
I have a wire feed welder. I add 2 spot welds in same spots.
  #248
Old 12-28-2018, 02:59 PM
BrandonSmith
Name that seat!! My cousin bought his bike with that seat on it and he has no idea what it is, but it’s comfy and the passenger part looks a bit comfier than my stock SG seat.
  #249
Old 01-01-2019, 09:39 PM
BrandonSmith
First of all, great bike and nice detailed thread to monitor progress, I wish I would have thought of this, I have done numerous upgrades over the past 2 years.
I noticed your license plate frame. I had a similar one, it was awfully ugly. I found the curved plate frame on the forums. Man what a difference. Check it out. I think it would clean up your back real nice for like $40. Keep up the good work.
Hey, man! I realized there was something missing from the rear of my bike... What curved mount do I need to get?
  #250
Old 01-03-2019, 01:04 PM
BrandonSmith
Well, my bike's in-service date is 1/26/17 which means it's about to be two years old, which means it's time for the bike's first brake and clutch fluid replacement. I'll be holding off on doing the clutch fluid since HD will be doing that during the recall work (I'm #342 on the list at Timms HD of Augusta and they've only been getting 2-3 kits per week, so... Next fall? lol)
I bought a large syringe from
Amazon Amazon
to reverse bleed the system, which I tend to find easier to complete without help, and I feel it yields better results, especially on a small system like a motorcycle. I chose the 150mL syringe since it holds more than the required amount of fluid for each brake line per the manual (3 fl.oz, 89mL), which is also the amount of fluid the reservoirs hold.
Plan of attack: Suck all fluid from reservoir, shoot it in an empty bottle, suck in ~3.5 fl.oz. of new fluid, shoot it into the caliper, rinse and repeat for each line.
Quick Reply: Brandon's 2017 FLHX
