Any idea what the stock air filter flow rate is?
I know it flows plenty for the Stage 1 Street Tuner calibration and Street Canons. I left the stock air cleaner alone and it runs fantastic. Pulls strong and smooth all the way to Redline. I think it's fine until you go to Stage II and up. All those SE air kits are designed for their performance upgrades thru Stage 4. If you think about it, when they redesigned the new motor and increased overall air flow they didn't neglect the intake and design it to be exactly just enough for the stock calibration with a brand new filter.
the stock filters are still paper, and smaller than the synthetic media kit upgrades..but they are washable..for $20 apiece I bought several and just make sure to rotate them before they get too dirty..I like the better filtration overall weather protection for touring, and think the design of the air box itself lends to getting enough air past the filter into the throttle body..just my opinion based on early impressions..I see no need to upgrade my intake
I haven't bothered to put the M8 OEM filter on the flowbench, however the element is tiny and the media section is only just over an inch thick. On average we see a solid 2-3 Hp in Stage 1 applications with the various M8 prototype & pre-production air cleaners we have tested for several manufacturers.
Here are some images of the stock element
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
cster8888 (05-27-2018)
well if you believe the DYNO chart Harley provides for their Stage 1 with Street Canons, Heavy Breather and Stage 1 calibration, and don't know why we shouldn't because the published gains are so nominal, bordering on anemic for cost/value .... couple hp throughout and 5 tq at 3500 (small but at least in the right spot)..and with the street canons and S1 recalibration w/stock intake the gap is even smaller...way I see it I might gain 1 hp and couple TQ if I upgraded my stock airbox to a $400 SE HB.
So my perception is a $400 upgrade gets me an almost imperceptible performance gain, that is noisier, has to be serviced/oiled, passes more airborne contaminants and have to screw around with a rain sock.
http://www.boardtrackerharleyonline....ed/2017_SE.pdf
I put the ventilator filter on bigger than stock cost 289.00 no sucking noise and I have run similar open filter a/c on all my bikes in rain that was hard enough that each breath was a drink of water no problems I don't even cover them at nite when it rains in 10 yrs and 10's thousand of mile using them never an issue. I did hear the SE HB has a whistle to it. Just my 2 cents
mjwebb (12-14-2016)
good feedback/conversation..I just think at the end of the day it comes down to..Stage II and above absolutely necessary to upgrade A/C (obviously)..Stage 1, not so much..especially on touring bikes where the overall protection and quietness the OEM unit provides is more important than a couple of ponies
bpav16 (04-08-2018)
