Anyone doing the breather bypass on your M8?
Old 07-08-2022, 05:54 PM
OldMike's Avatar
OldMike
OldMike is offline
Received 1,927 Likes on 1,260 Posts
Originally Posted by Durham man
I saw your intake manifold, is it possible that going to the stage 3 was the fix and not the external breather now that you have seated rings and a healthy running m8? What level do you keep oil at?
Engine braking causes carbon deposits from oil getting past the rings, I think some of this oil gets into the manifold too because of vacuum, this and additives in gas I believe caused piston deposits and manifold oil in my 3k old engine that was bypassed when new (6 miles). Note: My stage IV is using less oil than the stock 114, fitted pistons, and I consciously do less engine braking.
https://ricksfreeautorepairadvice.co...-cause-damage/
The following 2 users liked this post by OldMike:
Durham man (07-09-2022), Old Ranger (07-08-2022)
  #722
Old 07-09-2022, 08:29 PM
Klock20's Avatar
Klock20
Klock20 is offline
I did the zerk fitting mod grind down the end a bit and push out the ball and spring drill and tap the air cleaner bracket looks pretty clean I just got back from a 2500 mile trip it didn't drip oil at all 2022 low rider s 117
  #723
Old 07-10-2022, 09:21 PM
Spook13's Avatar
Spook13
Spook13 is offline
Did the DK Outlaw breather bolts and the 587 air cleaner. Rode about 75 miles today and no oil to be seen.😀
  #724
Old 07-10-2022, 11:28 PM
Hairy Larry's Avatar
Hairy Larry
Hairy Larry is offline
Big Kahuna HDF Member
Received 4,605 Likes on 3,219 Posts
To be honest I can not be 100% certain what caused the breathers to stop puking oil but I am certain there is no oil in my new aluminum manifold.
Durham man (07-11-2022)
  #725
Old 07-11-2022, 07:09 AM
OldMike's Avatar
OldMike
OldMike is offline
Did you look behind the throttle blade?
I keep my oil level low and never got oiling on the filter or the front of the throttle body, but it did show up behind the blade in the manifold while being externally vented or not.
  #726
Old 07-16-2022, 01:01 PM
686 Shooter's Avatar
686 Shooter
686 Shooter is offline
Install the Trask Check M8. No oil in the filter while allowing proper crankcase ventilation. You can thank me later.
  #727
Old 07-16-2022, 01:07 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 6,255 Likes on 3,411 Posts
I finally caved, and bought one from Fuel Moto. How much redundancy are we talking when you have the Trask, and the external vent in place?
  #728
Old 07-16-2022, 01:15 PM
686 Shooter
It wont effect anything by having the external vent with the Check M8. If you had left the air cleaner ventilation as is it can help toward having a slight vacuum in the crankcase, which is ideal. But having the external breather mod and the Check M8 won't negatively effect anything. You'll still be getting better crankcase ventilation.
NorthWestern (07-17-2022)
  #729
Old 07-16-2022, 02:36 PM
scj's Avatar
scj
scj is offline
Vented mine. Drilled the backplate and installed a "T" inside the air cleaner and ran the hose out and down below the frame.
  #730
Old 07-16-2022, 02:42 PM
GreenMonster's Avatar
GreenMonster
GreenMonster is offline
did pretty much the exact same thing pretty easy
Quick Reply: Anyone doing the breather bypass on your M8?
