Anyone doing the breather bypass on your M8?
Old 04-10-2020, 10:49 AM
Redrodyankneck's Avatar
Redrodyankneck
Redrodyankneck is offline
Originally Posted by iHodor
I hope that's exactly what it is!
When a tiny hose is left in a large throttlebody there is no suction going on. Proply rings seating.
  #562
Old 04-10-2020, 02:32 PM
Fullbore55's Avatar
Fullbore55
Fullbore55 is offline
Received 2,730 Likes on 1,264 Posts
Originally Posted by GlidingJoe
I would bet if this was a big bore build and put on a dyno, that arraignment would certainly produce lower numbers than without. Maybe not significant, but something. Not criticizing the work, just commenting on how something as simple as the screen can alter the air flow and the hose that appears to be in the air stream. I too would suggest drilling an additional hole and relocating the right side directly out and connecting the two behind the back plate. It would also remove the uphill tube.
I doubt you could measure any difference due to the screen, especially as the air has to also pass thru the filter.
  #563
Old 04-10-2020, 08:57 PM
Redrodyankneck
It has to do more with turbulence, the flow should be smooth going into the throttlebody.
GlidingJoe (04-11-2020)
  #564
Old 04-10-2020, 10:06 PM
Fullbore55's Avatar
Fullbore55
Hey Redro, sounds like you know your fluid dynamics. I hadn’t considered the turbulence aspect.
Do you have a bypass?
  #565
Old 04-12-2020, 09:08 AM
3dognate's Avatar
3dognate
3dognate is offline
hmmm.... how would I go about a breather bypass on a Heavy breather? Would not be able to do the banjo type hose barb.
  #566
Old 04-12-2020, 09:17 AM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 9,368 Likes on 4,779 Posts
my doctor recommended a C-PAP
The following 3 users liked this post by mjwebb:
3dognate (04-18-2020), GlidingJoe (04-13-2020), iHodor (04-12-2020)
  #567
Old 04-12-2020, 12:15 PM
iHodor's Avatar
iHodor
iHodor is offline
I see what you did there MJ
mjwebb (04-12-2020)
  #568
Old 04-18-2020, 09:49 AM
iHodor's Avatar
iHodor
iHodor is offline
Default Nothing but water
After two rides on consecutive days this week I checked my catch can. It had about 2 tablespoons of very clear water in it, presumably condensation, with no hint of oily residue. Filters are clean also. So end result for me seems to be promising. Nothing going into the intake and no excessive dumping of anything including oily blowby coming out of the heads. If this keeps up I may do away with the catch can and route it straight to ground via a rubber hose.
  #569
Old 04-18-2020, 10:28 AM
BatOuttaHell's Avatar
BatOuttaHell
BatOuttaHell is offline
I just installed the Heavy Breather and also want to do the install. I think the only way is to drill/tap the supports and install NPT fittings and hose to the ground, catch can or filter.
  #570
Old 04-18-2020, 12:03 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
Finally got around to doing mine today. Used the OE tee fitting from the stock hoses and grabbed 7/32 hose from auto parts store. Drilled a hole in the backplate just big enough to slide the hose through and routed it down between the two forward pushrod tubes, behind the oil sender and zip tied to the frame. Can’t really see anything is different once the cover is back on.
The following 2 users liked this post by dawg:
OldMike (04-18-2020), voodoodrug (04-18-2020)
Quick Reply: Anyone doing the breather bypass on your M8?
