Anyone doing the breather bypass on your M8?
Old 11-06-2019, 01:10 PM
cj24's Avatar
cj24
cj24 is offline
Originally Posted by DK Custom
The hose that comes with the DK EBS Kits will not melt if in contact with the push rod tubes. Never seen it melt against the fins either. I suppose if the engine was running far too hot for it's own good, the hose may melt/deform if held tight against the fins.
The hose on my bike is routed right against the push rod tubes AND the engine block (below the oil filter) and has no issues at all.
Excellent thank you. Sounds very similar how I plan to run mine. I thought the breather bolts alone (for my FLDE)would be enough... but after some long hard highway miles I get some drips and the wind wicks it a bit into my air cleaner cover. I think most would not worry about it... but I plan on some long trips in the heat and don't want to obsess over my oil levels and/or potential mess being made on my air filter lol
  #462
Old 11-06-2019, 02:01 PM
vegas-triker's Avatar
vegas-triker
vegas-triker is offline
I have the black fiber hose and it does burn upon contact
  #463
Old 11-06-2019, 02:04 PM
cj24's Avatar
cj24
cj24 is offline
that's good to know thank you. I am going with the rubber but I had considered the fiber
  #464
Old 11-06-2019, 03:49 PM
Birdog's Avatar
Birdog
Birdog is offline
I like the look of that hose. Where exactly does the hose terminate? Open ended or catch can or filter?
  #465
Old 11-06-2019, 05:58 PM
DK Custom's Avatar
DK Custom
DK Custom is offline
Platinum Sponsor
Received 4,238 Likes on 2,469 Posts
Yes, the black braided fiber hose will start melting around 350*, even at lower temps it will get wear marks if rubbing against something.
The stainless steel braided hose will tear up chrome, powder coat, and whatever else it touches.
I used to run a lot of the black braided fiber hose myself. It was difficult to install, and I did not want to worry about it getting wear marks from rubbing, so now I mostly use the plain rubber hose. Although, I still am running the Black Fiber on my Softail. Really like the way it looks.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
  #466
Old 11-06-2019, 06:23 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 6,273 Likes on 3,422 Posts
Parker used to make that push-lok hose in black, and it is high heat resistant. What size are the fittings for this? 1/4" ID? I was going to look it up
  #467
Old 11-06-2019, 06:30 PM
cj24's Avatar
cj24
cj24 is offline
Well who cares about the EBS I guess... most of us are running high flow air filters and according to latest post k&n will destroy your engine... lol... think it's best to stay offline and ride haha
  #468
Old 11-07-2019, 06:05 PM
vegas-triker
DK's new catch can... started with their old style but upgraded..nice new design
DK Custom (11-07-2019)
  #469
Old 11-09-2019, 10:12 PM
Highwaymans's Avatar
Highwaymans
Highwaymans is offline
Why not spend a little more time and work to run em up, back and run it down the frame and behind the trans out of sight?
  #470
Old 11-09-2019, 10:48 PM
cj24's Avatar
cj24
cj24 is offline
Are there stealth breather bolts with tubes that run upward like that? DK has them for twin cam but not M8. Using the regular breather bolt's and just looping the rubber upward is more noticeable than downward imo
Quick Reply: Anyone doing the breather bypass on your M8?
