Anyone doing the breather bypass on your M8?
#221
Received 4,238 Likes
Ness ran out of bolts a few months ago, and they still don't have an ETA on them, so we cannot say. However, if you send yours in we will modify them to work with whichever kit you want. Call or email if you'd like to have that done.
GREENOHAWK69 (09-17-2018)
#222
DK Custom;17668716]We make, and have been making, quite a few different A/C's with External Breather Systems (EBS) for the M8 for 2 years now. You can see them at these two links- LINK1 & LINK2. The second link has a Performance A/C that works with the stock cover.
You can also see a variety or EBS kits for the M8 that will work with air cleaners that do not have them built in, at this LINK [/QUOTE]
Kevin, I've seen your screened breather bolts, and I had a question about them. Do they weep oil, since there are no hoses to direct the oil away? Also, I understand the oil "vapor" would be vented to atmosphere, but with the breather bolts, would the "milky snot" we see in some of these pics not just run back down into the crank case? Thanks for taking the time to address the issues discussed here.
#223
Kevin, I've seen your screened breather bolts, and I had a question about them. Do they weep oil, since there are no hoses to direct the oil away? Also, I understand the oil "vapor" would be vented to atmosphere, but with the breather bolts, would the "milky snot" we see in some of these pics not just run back down into the crank case? Thanks for taking the time to address the issues discussed here.[/QUOTE]
The Breather Bolts work well for most Sportys, and they work well for about 40% of all Twin Cams and M8's. The majority of TC's and M8's spit too much oil out of the breathers, overwhelming the small filter on the Breather Bolts. There is no way to know which ones they will work well on or not...BUT, if it is built, as yours is, the probability is high that it will overwhelm the Breather Bolts. Best to choose an EBS option that utilizes a filter at the end of a hose.
#226
#228
#229
#230
