Anyone doing the breather bypass on your M8?
Old 03-04-2018, 09:04 AM
VDeuce's Avatar
VDeuce
VDeuce is offline
Originally Posted by Blue Tick
Can you post some pics of what you did?
Drilled/tapped backplate for 1/8 NPT - 5/16 HB. The barbs are screwed into the brass inserts as shown.
Then drilled tapped for 8-32 set screws red loctited in place and doubled up to block internal passages...
I asked S&S support if anyone had done this and he said I was likely the guinea pig, so I just had to lol. There's no way with my build I am dumping crap back into my intake.
I chose this AC over others for what I thought would be ease of modification and it worked well. I don't like the Heavy Breather or oval style ACs, so this fit the bill. Will probably run this with the 1" taller filter.
The following 3 users liked this post by VDeuce:
hoofnhog (03-06-2018), madmat (03-04-2018), paid4c4 (03-04-2018)
  #172
Old 03-04-2018, 01:14 PM
HDs4me's Avatar
HDs4me
HDs4me is offline
Originally Posted by badcooky
Why I oughta !
oughta what post a pic OR admit you not taken the breathers out
  #173
Old 03-04-2018, 04:13 PM
splattttttt's Avatar
splattttttt
splattttttt is offline
Seriously **** you man ! ha ha.
Here’s mine man. Com’n bro! Where’s the meat?
  #174
Old 03-05-2018, 07:42 PM
badcooky's Avatar
badcooky
badcooky is offline
Splatt that's a Twin cam doesn't count.
HDS4ME where's your M8 breather picture man ?
I just put the end of the breather out into the air stream.
Attached Thumbnails Anyone doing the breather bypass on your M8?-06032018.jpg
  #175
Old 03-05-2018, 08:18 PM
Retrop's Avatar
Retrop
Retrop is offline
Stage I M8 air cleaner external breather using K&N filter.
It is mainly moisture being discharged (especially when it is cold) and a small amount of oily mist. Left to it's own it does not get sucked into the butterfly and drools down the face of the back plate where it ends up on the rubber gasket of the OEM air filter. When enough of it accumulates it pukes out the milky mixture via osmosis which blows on the rear exhaust pipe, cam chest and the front of the right hand saddlebag. Dealer said nothing he could do. I might have mentioned that I thought it was another case of PP engineering on the part of the MOCO.
I did have to drill a hole in the back plate to run the rubber windshield wiper hose through. Two feet of hose and two plastic t's to connect the hoses together was pretty much all I needed. The hose ends slipped right over the existing breather bolts.
Attached Thumbnails Anyone doing the breather bypass on your M8?-dscf2863.jpg
FLAGLIDIN (12-15-2021)
  #176
Old 03-06-2018, 01:49 PM
Geary Thomas's Avatar
Geary Thomas
Geary Thomas is offline
That was a nice fix... Never stopped to think of it, just purchased the bolt replacments
  #177
Old 03-18-2018, 09:43 AM
Doshounds's Avatar
Doshounds
Doshounds is offline
What size tap did you use on the NPT fitting? Doing mine today.
  #178
Old 03-18-2018, 09:55 AM
VDeuce's Avatar
VDeuce
VDeuce is offline
Fitting was 1/8 NPT to 1/4 HB - I forget exact tap size. If you do a Google search on tap size and it will indicate what you need. I had 1/8 NPT to 5/16 HB, but though that was too large so went with the 1/4 HB. I also removed the thread tape and went with Loctite thread sealant (white)
  #179
Old 03-18-2018, 10:06 AM
Doshounds's Avatar
Doshounds
I appreciate it. I just went to Home Depot to find thread size and they didn’t sell taps in the size I needed. I will do a quick search and get the correct info. Good thing I have two bikes if I have to order a tap. 👍
  #180
Old 03-18-2018, 10:13 AM
VDeuce's Avatar
VDeuce
VDeuce is offline
I appreciate it. I just went to Home Depot to find thread size and they didn’t sell taps in the size I needed. I will do a quick search and get the correct info. Good thing I have two bikes if I have to order a tap. ��
I found my tap at a local Ace Hardware. Good luck! Oh and if you do go to Ace and they have Dot's Pretzels, gotta try 'em they are addicting.
Doshounds (03-18-2018)
Quick Reply: Anyone doing the breather bypass on your M8?
