M8 advanced oil cooler system
Old 12-30-2016, 07:47 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 9,343 Likes on 4,767 Posts
Originally Posted by bwoltz
Thinks for the info but as I understand it,, Engine temp and cylinder head temp are not the same.. IIRC. Engine temps is some convoluted value that uses something like head temp and air inlet.. Anyone know for sure is engine temp is indeed cylinder head temp?
no idea, but bet Steve, who provided the data knows this stuff inside and out
  #162
Old 12-30-2016, 08:31 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
Originally Posted by sixguns
Not sure what to think with the conflicting stories as to when the fan should be on. Mine has never been on yet. Was at the dealer today and its enabled, the techs say it wont come on till the oil reaches temp. He did not know what that temp was but he says its not coming on in this cold weather unless I was to idle the engine a very long time.
After reading all these posts, I wonder if the tech was correct about the fan not coming on until the oil reaches a certain "unknown" temp. I have looked at the parts catalog for the M-8 and I can't find any mention of a oil temp sensor. I really doubt that the M-8 has any oil temp sensor when it's never been used in earlier HD bikes. HD doesn't even offer a oil pressure sensor that can display oil PSI like earlier bikes. Maybe the fan gets triggered by the engine temp sensor that appears to be mounted in the rear head.
  #163
Old 12-30-2016, 08:37 PM
mjwebb's Avatar
mjwebb
it's thermostatically controlled is all I know
  #164
Old 12-31-2016, 06:45 AM
14GuineaPig
The 2017 Police Service Manual Supplement (94000387) or the 2017 Trike Models Service Manual Supplement (94000391) might have some information as the fan equipped oil cooler is standard on those models that have the M-8 air cooled engine.
I should say that I'm just curious as I don't own a M-8. Steve Cole seems to be very knowledgeable about these new M-8 bikes so maybe he'll provide the answer.
MJ - a quick question for you, does the oil cooler appear different from the stock one or is it the same cooler just with the addition of a fan?
  #165
Old 12-31-2016, 07:17 AM
mjwebb's Avatar
mjwebb
appears to be the same cooler just with the addition of a thermostatically controlled fan..dimensions are the same as it fits exactly in the place of the OEM cooler and cover
14GuineaPig (12-31-2016)
  #166
Old 12-31-2016, 08:53 AM
lp's Avatar
lp
lp is offline
Received 2,834 Likes on 1,595 Posts
He does too. Still...I'm waiting to hear from someone that knows what temp or conditions must be met for the fans to come on. Asked Steve and this was his response.
Originally Posted by Steve Cole
It turns on and off based on what HD figured it needed. I could get into the calibration and change it but I want to start with using it just as they have it set.
So... still waiting to learn more.
  #167
Old 12-31-2016, 09:23 AM
14GuineaPig
Well I'm going to bet that HD is using the Engine Temp Sensor that is installed in the rear head. I say this because the 2 models that come standard with the fan assisted oil cooler (police & freewheeler) don't have radios so they also don't run Ambient Air Temp Sensors (no place to display the air temp info). And we know HD removed the oil pressure PSI display (not that either of these models could display it) in favor of "Check Oil' & "OK". Some say this was done to reduce customer inquires/complaints about oil pressure. Based on that assumption, there isn't any way that HD would now install an oil temp sensor that could provide info on oil temps. They would have to have a dedicated customer service rep just to answer the added calls. Also, when looking at the parts for the fan assisted oil cooler, there isn't any oil temp sensor or thermostat listed. Just my guess ... waiting for info from someone who knows.
  #168
Old 12-31-2016, 09:49 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,957 Likes on 4,033 Posts
So the head temp sensor is the engine temp?
What about the air inlet temp?
Makes sense on removing the oil pressure and not having oil temp. People would likely freak out..
  #169
Old 12-31-2016, 10:08 AM
14GuineaPig
  #170
Old 12-31-2016, 10:59 AM
boston jim's Avatar
boston jim
boston jim is offline
Contact IB Sales to have your account opened
Hey Nomad, It's a fact that ALL the oil doesn't go thru the Oil Filter of a Twin Cam ! I read somewhere the M8 uses the same oil filter as the Twin Cam? The Infamous Donny Peterson, stated in AIM, 10/15 years ago, that the Evo oil filter was 30 micron, the Twin Cam at the time was 10 micron, with a more powerful oil pump, than the Evo. Donny's theory was the Twin Cam filter was too restrictive, & with a more powerful oil pump, oil would back up, build pressure, & the By-pass valve would open, all too often! He thought using an Evo 30 micron would allow more oil to flow & be filtered. My understanding now, is the Twin Cam filter is 5 micron, is that correct? If that is the case, the more powerful M8 oil pump will back up oil, opening the By-pass valve, letting unfiltered oil into the motor & oil cooler, crap blocking oil passages ? Happy New Year, BJ
PS, I'd like to hear Steve Cole comment, on my comment!
PSS, While poking around here last night, before I went out to dinner, I stumbled onto WWW.ULTRACOOLFL.COM, check it out!
Quick Reply: M8 advanced oil cooler system
