M8 advanced oil cooler system
Old 12-29-2016, 03:54 PM
CR3999's Avatar
CR3999
CR3999 is offline
Are the bikes water cooled, on the bikes that the fan doesn't come out?
After I got home I realized the water cooled don't have oil coolers. My bad.
  #152
Old 12-29-2016, 03:56 PM
SWThomas's Avatar
SWThomas
SWThomas is offline
Received 1,093 Likes on 655 Posts
Originally Posted by mjwebb
yeah, I'm really curious as to how these issues get resolved..1 year warranty, wife's will be factory 2 year..'if' mine fails outside that I'll throw the OEM on and switch to synthetic instead of shelling out another $400 ish..but getting way ahead of myself here as I don't believe there's a 50% failure rate..LOL..did anyone try 'rebooting' it by unplugging and plugging it back in? worth a shot I suppose...but yeah, if you ride it until operating temperature, park and let it idle while putting you're hand down there, there will be zero doubt if it's on or not
I took your earlier advice and checked to ensure it was plugged in all the way. It was but I unplugged it and plugged it back in anyway. I'll find out if it fixed it next time I ride it. If not, I'll take it to the dealer next week and see what's what. But if yours is coming on in 50 degree weather, mine should have definitely come on riding as many miles as I did yesterday with temps in the 60s.
  #153
Old 12-29-2016, 04:18 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 9,343 Likes on 4,767 Posts
most definitely take it in, doubtful the 'reboot' makes a difference but I'm in an IT profession..strange unexplainable things happen..and as I mentioned earlier, it comes on in 30 degree weather
  #154
Old 12-30-2016, 06:21 AM
cruisinmann's Avatar
cruisinmann
cruisinmann is offline
Received 1,808 Likes on 628 Posts
When I rode mine with temps in the 60's it didn't come on either. I have a temp gauge on dipstick and oil temp never got above 225. Now it will be a couple months before I can ride it again
  #155
Old 12-30-2016, 08:41 AM
SWThomas's Avatar
SWThomas
SWThomas is offline
Maybe MJ's Road King just runs abnormally hot.
  #156
Old 12-30-2016, 08:49 AM
mjwebb's Avatar
mjwebb
could be the regular dose of 5000 rpm's, it's so much fun I just can't help myself
  #157
Old 12-30-2016, 08:58 AM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,480 Likes on 761 Posts
While on the subject of heat, I have yet to feel any coming off the motor. The M8 does run much cooler than the Twincam.
  #158
Old 12-30-2016, 09:18 AM
mjwebb's Avatar
mjwebb
after my early September hot rides I noticed it was more comfortable than my Rushmore, but still felt the heat at stop lights..EITMS kicked on earlier and often was my perception..the thing that convinced me of their claim to have reduced exhaust gas temperatures by 100 degrees was my exhaust header color..there isn't any of the pretty blue and gold of my previous bikes!
  #159
Old 12-30-2016, 09:32 AM
sixguns's Avatar
sixguns
sixguns is offline
The old Head pipes blued from the being somewhat chromed. The new head pipes are not chromed and much better to look at. My Rushmore head Pipe was a butt ugly weld splattered cheap chromed Blued POS. Fuel Moto Jack Pot SS coated came to the rescue.
mjwebb (12-30-2016)
  #160
Old 12-30-2016, 07:14 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,957 Likes on 4,033 Posts
Steve did a great job of capturing, tracking and reporting these tests and results so I'll try to save him a little time unless he has something more to add, but here's what he posted, with the caveat the after upgrade tests were performed in "5-8 degree cooler weather" but identical test ride route, traffic, speeds, etc...but sure looks positive
Before Upgrade Results:
Measured Peak Engine temperature = 340 F
Measured Peak Oil Sump temperature = 267 F
Measured Peak Head Oil Return temperature = 290 F
After Upgrade Results:
Measured Peak Engine temperature = 302 F
Measured Peak Oil Sump temperature = 201 F
Measured Peak Head Oil Return temperature = 240 F
Thinks for the info but as I understand it,, Engine temp and cylinder head temp are not the same.. IIRC. Engine temps is some convoluted value that uses something like head temp and air inlet.. Anyone know for sure is engine temp is indeed cylinder head temp?
Quick Reply: M8 advanced oil cooler system
