M8 problems
Old 07-08-2017, 06:31 PM
Drew miz's Avatar
Drew miz
Drew miz is offline
Stage II
I will check
  #672
Old 07-08-2017, 06:51 PM
texaswiz's Avatar
texaswiz
texaswiz is offline
If you put the recommended amount of oil in the crankcase you will probably be alright for a good part of the year. But, if you put in the recommended amount of oil and the summer heat goes up to 85-95 degrees and you ride at 70-75 mph, the oil in the crankcase has no where to expand to except out the air cleaner. Very common in the hot summer. Most guys just suck some out of the fill hole with a turkey baster and go on their way. I run my M8 3 dots down from the top of the dipstick when I check it hot. When the engine is cold and you check it you will find it about 6 dots from the top. Not a big deal by any means, but you should take it into your friendly Harley Davidson service department so they can put your mind to ease. Things like this are not covered in the owner's manual. I am sure others will come in with their opinions as well.
  #673
Old 07-08-2017, 07:36 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,960 Likes on 4,035 Posts
M8 have a hot and cold level on the dip stick..
Nothing wrong with running it mid level tho..
  #674
Old 07-08-2017, 08:56 PM
texaswiz's Avatar
texaswiz
texaswiz is offline
Maybe we have different M8 engines.
My dipstick does not have a HOT level and a COLD level on the dipstick.
It does have a Full HOT Jiffy stand chart on the "upper" portion of the stick. The "bottom" chart on the stick is for a Full HOT Vehicle Upright reading.
The service manual does say the "Oil level on a cold engine should never be above the midway point" on the stick.
  #675
Old 07-08-2017, 09:25 PM
Max Headflow
Yep you are right.. Hot upright and hot sidestand.. I guess the thing is that you shouldn't need to run below the high hot level if the oil level is checked while hot..
  #676
Old 07-08-2017, 10:18 PM
CheefASRC's Avatar
CheefASRC
CheefASRC is offline
Default 2017 RKS 1300 miles
weeping oil from rockers. Have an appointment 7/19 to swap out gaskets and rockers. Stay tuned. HD dealer says known issue my bike is number 5
  #677
Old 07-09-2017, 09:26 AM
rwales1's Avatar
rwales1
rwales1 is offline
Default Glad I saw this
I looked at getting a new '17 Street Glide Special last year and held off on a first year model, glad I did. Was just looking again as I now have a problem with mine, but after reading some posts on here I'm going to hold off. So glad I found this forum. Thanks
Krieg (07-09-2017)
  #678
Old 07-09-2017, 11:15 AM
Krieg's Avatar
Krieg
Krieg is offline
Because of this thread, I opted to stick with the 103. So glad I did.
  #679
Old 07-09-2017, 12:54 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 9,345 Likes on 4,768 Posts
103 is a mature engine..they don't run nearly as nice as the 107 but for folks that are jittery about spending thousands and being let down by potential issues then 103 is a solid choice and the money spent on upgrading can be spent on going on more rides..I've had a couple 103's and they provided me with many thousands of trouble free miles and memorable trips so that's what riding is all about at the end of the day..Ride On!
  #680
Old 07-09-2017, 01:43 PM
Nuke_Disaster's Avatar
Nuke_Disaster
Nuke_Disaster is offline
Default This...
this happened today....
Quick Reply: M8 problems
