M8 problems
Old 11-04-2016, 07:57 PM
splattttttt's Avatar
splattttttt
splattttttt is offline
Originally Posted by ChrisHo
it doesn't look to be putting out enough to drip, but what I will do is measure the oil in the morning. Wipe it spotless. Take it out for 15 and photo it running when I get home.
that'll be good info. Knowing the MOCO's chasin this one in particular.
  #172
Old 11-05-2016, 09:02 AM
ChrisHo's Avatar
ChrisHo
ChrisHo is offline
Received 4,523 Likes on 1,414 Posts
My cases appear fine, cylinders are fine. This all appears to have just started from the oil cooler connection to the engine. From the oil cooler to the bottom right.
I completely cleaned everything except this connector as I only discovered the true source after this mornings ride. Had a guy check it out at a local charity ride and he agreed its the connection that is failing.
Cold measure is 3 dots above add a quart. This just started sometime this week, was caught by friend's wife who joked about it (her old 883 had a leak early on).
Regardless, dealer said he would come get it and not to ride it so I will let them take care of it. It will wet a paper towel if I wipe it down all the way back to the front, these are after the second ten minute loop to confirm source.
Right front, oil cooler connection, looking down on it
right underside, was perfectly dry before 10 minute run
doesn't look like much but if I wipe off this going forward to oil cooler I can wet a paper towel
  #173
Old 11-05-2016, 09:51 AM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
This is what scares me and keeps me from even considering a trade. With my bad knees, I would have trouble getting down to inspect or look for issues like this. Looks like I'm sticking with the 103 for a while.
  #174
Old 11-05-2016, 01:32 PM
ChrisHo's Avatar
ChrisHo
ChrisHo is offline
Well we now wait on parts which is fine. Apparently this connector goes into the crankcase and needs to be replaced along with two other pieces. I got lucky in that I didn't ride it much after first finding it as I guess it could go bad really fast. Wish there was a part fiche to see what pieces are there
  #175
Old 11-05-2016, 03:07 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
Default You lucked out.
The positive side is that it will be covered by warranty. Better yet, you weren't on a long trip, fully loaded with gear and clothes.
  #176
Old 11-05-2016, 05:44 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
I think your talking about #10
ChrisHo (11-05-2016)
  #177
Old 11-05-2016, 06:28 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
You da man 14GuineaPig !
  #178
Old 11-05-2016, 07:26 PM
ChrisHo's Avatar
ChrisHo
ChrisHo is offline
nice find, I was searching all over that other site and could not find that image.
So it appears they have to replace the 6,10, and 11 on my Road King.
and here I was hoping to put the lowers on this weekend.
  #179
Old 11-05-2016, 07:37 PM
splattttttt
Willing to bet that as soon you replace factory lubes to a better quality synth type, those parts will oerform as they should
  #180
Old 11-05-2016, 08:15 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,480 Likes on 761 Posts
Your bike and Im sure you know whats going on with it, but 6&11 would be used when #10 is not used. Sounds like your getting a new check valve, could be a new clamp and hose too. Wish you and your bike a quick repair for sure.
Quick Reply: M8 problems
