Ironhead A place to talk about Ironheads.
Ironhead sportster charging problems
Old 05-30-2014 | 06:19 PM
little5150's Avatar
little5150
Default Ironhead sportster charging problems
I have a 1982 sportster and my generator light started staying on. With the generator on a workbench, I did the test where you ground out the F (field) terminal to the generator body with a small jumper wire and took a battery and hooked up the negative from the battery to the body of the generator. Then I hooked the positive from the battery to the A (armature) terminal. This should make the generator run like a motor, Right? and if it dose its good. Well mine doesn't. Its been a long time since I did this test. Dose anybody know if I am doing this test right to find out if the generator is bad or not. I did polarize the system and bought a new rebuilt generator and regulator. And the light still stays on all the time. I think I got a bad rebuilt generator. Thanks
Old 05-30-2014 | 08:21 PM
IronMick's Avatar
IronMick
It goes like this ...
1. jumper Batt+ to A
2. jumper Batt- to F
3. jumper Batt - to the gen body
For #3 you have to find a good spot, perhaps with no paint, and ensure that you are making a good connection.
Gen light staying on may be just a stuck brush. Remove gen from bike, take off the end cap, use electrical contacts cleaner to clean it all up, inspect the brushes, etc.
ChooChooCharlie
Ironhead
16
03-30-2016 03:02 PM
sportster77
Ironhead
05-20-2010 02:21 AM
1stsporty
Ironhead
04-04-2010 12:37 PM
Tips82
Ironhead
06-19-2009 06:33 PM
